Support file search path - incorrect - lost shortcuts , hatching etc
I am using autocad 2006 and have inadvertently deleted the 1st path in the dropdown under support file path and as a result I cannot use any shortcuts, right clicks, hatching etc. I have tried to follow instructions for the default path for profile, templates and configuration files but still have no joy, any ideas please?
That first line should look similar to this:
C:\Documents and Settings\yourusernamehere\Application Data\Autodesk\AutoCAD 2006\R16.0\enu\support
You could also create a new profile, set it to the default settings and use that as a reference for checking the paths in your profile.
Also, you can substitute %APPDATA% for the "C:\Documents and Settings\yourusernamehere\Application Data" part. That way it will work in any situation, without having to know the Windows profile name.
