Hello everybody.
Any one know how to give shadow in 2d drawings.is it possible?
Regards_______:(
You'll have to make a boundery (with polyline) and hach it with either a light gray solid or a not to dense hatch like stripes or sand.
Thanks for your replay Brands.
The method you suggested only for the horizontal and vertical object.yes i know this method.
How can i give shadows to a tree,like the way we used to make a freehand pencil sketch.
So i have to make polyline for the shadows and hatch it?
Like this ........
Regards________:(
house Model (1).pdf
You basicly need to use the same techniek as with the other shadowing. Only you have to put in a bit more effort, because on the treetrunk you can't use one straight line.
Not like this:
more like this:
But not as hastly as this.
Thanks Buddy.
But i need little more explanation.if u have a finished stuff of shaded 2d dwg please attach here.for get ideas.thanks in advance.
Regards________:(
Oeh, I don't get to use it to often in my work.
But I just had a project in witch I used shadows.
Thanks a lot Brands.
Regards________:)
The trick is to use not to mutch. I normally dont work with shadows because it disracts you. I work a lot with depth and sutle shadowing by the use of pointthickness.
