skipsophrenic Posted September 22, 2009 Posted September 22, 2009 Hi all, I've been searching through the forums, I know i've seen the answer before but i can't find it, so here goes: I've just recently had my computer updated to a newer model so before that happened I backed up my workspaces/profile/cui etc, everything else haworks like it did before, apart from 1 small problem, every time i enterd something in the command line before, whenever i pressed the up arrow it would repeat what i put, now however it's always coming up with the last absolute co-ordinates I was at, which is a little frustrating. Example:, I've used the DIV command on a line and now have a set of nodes I can snap to - i select XLINE and type in NOD, click on the first node, and then out of habit i press UP > ENTER, but this is now putting my next line ontop of my first one, not saying NOD at command line anymore, just a set of co-ordinates. If anyone knows which variable it is that i need to change, please let me know, as I rely on being able to quick-repeat commands that way, where as now i've had to open every toolbar out or every time i want to re-use a command I have to re-type it. Thanks Quote
GE13579 Posted September 22, 2009 Posted September 22, 2009 This is updated each year :wink: Edit... didn't really read the full post clearly... Edit of edit... are you still in the command? Quote
skipsophrenic Posted September 22, 2009 Author Posted September 22, 2009 nope, i've read the list VERY usefull if you already know part of command name, but i've forgotten the whole thing. Quote
GE13579 Posted September 22, 2009 Posted September 22, 2009 Are you still in an active command? Quote
skipsophrenic Posted September 22, 2009 Author Posted September 22, 2009 nope, i've done the nodes but it even happens when no command active, say i want to use LINE again, i press up with no active command going on and its still coming up with last used co-ordinates Quote
skipsophrenic Posted September 22, 2009 Author Posted September 22, 2009 Alanjt THANKYOU!!!!!! That's been driving me bannana's, i got to remember that command *runs off to write it down* Quote
alanjt Posted September 22, 2009 Posted September 22, 2009 Alanjt THANKYOU!!!!!! That's been driving me bannana's, i got to remember that command *runs off to write it down* No problem, had the same problem when we switched to 06 (I think that was the version). I just keep a list of setvars in my startup file that issue each time. (AT:Setvar "inputhistorymode" 0) Quote
