alanjt's Misc. Useful Lisp Subroutines
Thought I would start one of these. Modify them however you like. I prefix mine with AT: just to keep things organized, and it makes things easier to search through the atoms-family for loaded.
They are either stuff I use, stuff I've written just to write it, or posted posted somewhere and felt it was worth hanging on to.
If you like it, take it, if not, sorry.
;;; Remove Z value from point
;;; Alan J. Thompson, 3.18.09
(defun AT:FlatPoint (#Point)
(list (car #Point) (cadr #Point))
;;; Distance between 2 (no Z value) points
(defun AT:FlatDist (#Point1 #Point2)
(distance (list (car #Point1) (cadr #Point1))
          (list (car #Point2) (cadr #Point2))
;;; Convert point to a Vla Array
;;; #PointOrMessage - Point to convert, message for getpoint or nil for getpoint with generic message
;;; Alan J. Thompson, 05.23.09
(defun AT:VlaPoint (#PointOrMessage / #PointOrMessage)
 (or #PointOrMessage
     (setq #PointOrMessage "\nSpecify point: ")
 ) ;_ or
 (cond
   ((vl-consp #PointOrMessage)
    (setq #PointOrMessage (vlax-3D-point #PointOrMessage))
   ((eq (type #PointOrMessage) 'STR)
    (if (setq #PointOrMessage (getpoint #PointOrMessage))
    ) ;_ if
 ) ;_ cond
) ;_ defun
;;; Convert an Array or Variant to Standard List
;;; #ArrayVariant - Array or Variant to convert
;;; Alan J. Thompson, 08.14.09
(defun AT:ArrayVariant->List (#ArrayVariant)
 (cond
   ((eq (type #ArrayVariant) 'variant)
    (vlax-safearray->list (vlax-variant-value #ArrayVariant))
   ((eq (type #ArrayVariant) 'safearray)
    (vlax-safearray->list #ArrayVariant)
 ) ;_ cond
) ;_ defun
;;; Get angle of line ENAME
;;; #Line - Line ENAME to get angle from
;;; Alan J. Thompson, 09.08.09
(defun AT:LineAngle (#Line)
 (angle (cdr (assoc 10 (entget #Line)))
        (cdr (assoc 11 (entget #Line)))
 ) ;_ angle
) ;_ defun
;;; Convert Point List (X&Y) into Array
;;; #List - List of points to convert
;;; Alan J. Thompson, 09.16.09
(defun AT:PointXYList->Array (#List)
 (vlax-Make-Variant
   (vlax-SafeArray-Fill
     (vlax-Make-SafeArray
       vlax-vbDouble
       (cons 0 (- (length #List) 1))
     ) ;_ vlax-Make-SafeArray
     #List
   ) ;_ vlax-SafeArray-Fill
 ) ;_ vlax-Make-Variant
) ;_ defun
;;; Extract all Attributes from Block or Multileader w/Block
;;; #Object - Block/Multileader to extract attributes
;;; Alan J. Thompson, 08.17.09
(defun AT:GetAttributes (#Object / #Object #Entget)
 (if #Object
     ;; if list, strip out ename
     (and (vl-consp #Object) (setq #Object (car #Object)))
     (cond
       ;; if vla-object & multileader with block, convert to ename
       ((and (eq (type #Object) 'VLA-OBJECT)
             (vlax-property-available-p #Object 'ContentBlockName)
        ) ;_ and
        (setq #Object (vlax-vla-object->ename #Object))
       ;; if ename & block, convert to vla-object
       ((and (eq (type #Object) 'ENAME)
             (eq "INSERT" (cdr (assoc 0 (entget #Object))))
        ) ;_ and
        (setq #Object (vlax-ename->vla-object #Object))
     ) ;_ cond
     ;; run through options
     (cond
       ;; vla-object & attributed block
             (eq "AcDbBlockReference"
                 (vla-get-objectname #Object)
             ) ;_ eq
             (eq (vla-get-hasattributes #Object) :vlax-true)
        ) ;_ and
          (vlax-variant-value
            (vla-getattributes #Object)
          ) ;_ vlax-variant-value
        ) ;_ vlax-safearray->list
       ;; ename or entsel-style list
       ((or (eq (type #Object) 'ENAME)
            (vl-consp #Object)
        ) ;_ or
        (setq #Entget (entget #Object))
        (vl-remove-if
          '(lambda (x)
             (or (not x)
                 (not (eq "AcDbAttributeDefinition"
                          (vla-get-objectname x)
                      ) ;_ eq
                 ) ;_ not
             ) ;_ or
           ) ;_ lambda
          (mapcar
            '(lambda (x)
               (if (eq 330 (car x))
                 (vlax-ename->vla-object (cdr x))
               ) ;_ if
             ) ;_ lambda
            #Entget
          ) ;_ mapcar
        ) ;_ vl-remove-if
     ) ;_ cond
   ) ;_ progn
 ) ;_ if
) ;_ defun
;;;    AT:SetObjectLayer.lsp v1.0
;;;    (SubRoutine)
;;;    Copyright© 04.08.09
;;;    Alan J. Thompson (alanjt)
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    The following program(s) are provided "as is" and with all faults.
;;;    Alan J. Thompson DOES NOT warrant that the operation of the program(s)
;;;    will be uninterrupted and/or error free.
;;;    Civil 3D ONLY!
;;;    Set layer of specified Object Layer Setting
;;;    User is responsible for existince of Object Setting & Layer
;;;    Only tested in Civil 3D 2009
;;;    Arguments: #ObjType - Object type layer to alter
;;;           #Layer - Layer to set for above object type
;;;    Examples: (AT:SetObjectLayer 'GeneralNoteLabelLayer (getvar "clayer"))
;;;          (AT:SetObjectLayer 'GeneralSegmentLabelLayer (getvar "clayer"))
;;;    Revision History:
(defun AT:SetObjectLayer
      (#ObjType #Layer / #Version #AppNum #ObjLaySet #Result)
;;; 'GeneralNoteLabelLayer
;;; 'GeneralSegmentLabelLayer
 (vl-load-com)
 (cond ((setq #Version (vlax-product-key)
              #AppNum  (cond ;;2006
                             ((vl-string-search "R16.2" #Version) "3.0")
                             ;;2007
                             ((vl-string-search "R17.0" #Version) "4.0")
                             ;;2008
                             ((vl-string-search "R17.1" #Version) "5.0")
                             ;;2009
                             ((vl-string-search "R17.2" #Version) "6.0")
                             ;;No Match
                             (t nil)
                       ) ;_ cond
        ) ;_ setq
        (setq #ObjLaySet
               (vlax-get
                 (vlax-get
                   (vlax-get
                     (vlax-get
                       (vla-GetInterfaceObject
                         (vlax-get-acad-object)
                         (strcat
                           "AeccXUiLand.AeccApplication."
                           #AppNum
                         ) ;_ strcat
                       ) ;_ vla-GetInterfaceObject
                       'ActiveDocument
                     ) ;_ vlax-get
                     'Settings
                   ) ;_ vlax-get
                   'DrawingSettings
                 ) ;_ vlax-get
                 'ObjectLayerSettings
               ) ;_ vlax-get
        ) ;_ setq
        (vlax-put
          (vlax-get #ObjLaySet #ObjType)
          'Layer
          #Layer
        ) ;_ vlax-put
        (setq #Result (eq #Layer
                          (vlax-get
                            'Layer
                          ) ;_ vlax-get
                      ) ;_ eq
        ) ;_ setq
        (vlax-release-object #ObjLaySet)
 ) ;_ cond
 #Result
) ;_ defun
Edited by alanjt
;;; Extract number, northing, easting, elevation & description
;;; from Civil 3D point object. Only tested in Civil 3D 2009.
;;; #PointObj - Civil 3D point VLA-OBJECT
;;; Alan J. Thompson, 06.09.09
(defun AT:C3DPointInfo (#PointObj / #List)
 (and (eq (type #PointObj) 'VLA-OBJECT)
      (eq (vla-get-objectname #PointObj) "AeccDbCogoPoint")
      (setq #List (mapcar '(lambda (x)
                             (vl-catch-all-apply 'vlax-get-property (list #PointObj x))
                           ) ;_ lambda
                          (list 'Number 'Northing 'Easting 'Elevation 'Description)
                  ) ;_ mapcar
      ) ;_ setq
      (vlax-release-object #PointObj)
      (setq #List (vl-remove-if 'null #List))
      (setq #List (list (car #List)
                        (list (caddr #List) (cadr #List) (cadddr #List))
                        (last #List)
                  ) ;_ list
      ) ;_ setq
 ) ;_ and
 #List
) ;_ defun
;;; Insert all Page Setups into drawing (will overwrite if exists)
;;; #DrawingFile - name of DWG file from which to import
;;; Alan J. Thompson, 07.29.09
(defun AT:PageSetups (#DrawingFile)
 (if (findfile #DrawingFile)
     (command "_.psetupin" (findfile #DrawingFile) "*")
     (while (wcmatch (getvar "cmdnames") "*PSETUPIN*")
       (command "_yes")
     ) ;_ while
     T
   ) ;_ progn
 ) ;_ if
) ;_ defun
;;; Get/Set Variables
;;; Credit to: *ElpanovEvgeniy*
;;; (used his error function as an example)
;;; #List - list of variables (cmdecho, dimzin)
;;; #Get - if T, will create list of variables & values,
;;;        nil will set the previously created eval list
;;; Alan J. Thompson, 04.21.09
(defun AT:Vars (#List #Get)
 (if #Get
   (mapcar
     '(lambda (x)
        (list 'setvar x (getvar x))
      ) ;_ lambda
     #List
   ) ;_ mapcar
   (mapcar 'eval #List)
 ) ;_ if
) ;_ defun
;;; Setvar Replacement
;;; #Variable - Variable to set
;;; #Setting - Setting for setvar
;;; Example - (AT:Setvar "clayer" "A") -> "A"
;;; Example - (AT:Setvar "cclayerr" "A" -> nil
;;; Alan J. Thompson, 05.05.09
(defun AT:Setvar (#Variable #Setting / #Check)
 (if (not (vl-catch-all-error-p
            (setq #Check
                   (vl-catch-all-apply 'setvar (list #Variable #Setting))
            ) ;_ setq
          ) ;_ vl-catch-all-error-p
     ) ;_ not
   #Check
 ) ;_ if
) ;_ defun
;;; Check if two points are same
;;; Return: T if same, nil if different
;;; Alan J. Thompson, 04.28.09
(defun AT:PointSame (#Point1 #Point2)
 (equal #Point1 #Point2 0.00001)
) ;_ defun
;;;Check if two points are same X & Y (Z ignored)
;;;Return: T if same, nil if different
;;;Alan J. Thompson, 05.04.09
(defun AT:PointSameXY (#Point1 #Point2)
 (equal (list (car #Point1) (cadr #Point1))
        0.00001
 ) ;_ equal
) ;_ defun
;;; Write list to file
;;; #File - file to write list to (must be in form "c:\\File.txt")
;;; #ListToWrite - list to write to file
;;; #Overwrite - If T, will overwrite; nil to append
(defun AT:WriteToFile (#File #ListToWrite #Overwrite / #FileOpen)
 (cond ((and (vl-consp #ListToWrite)
             (setq #FileOpen (open #File
                                   (if #Overwrite
                                     "W"
                                     "A"
                                   ) ;_ if
                             ) ;_ open
             ) ;_ setq
        ) ;_ and
        (foreach x #ListToWrite
          (write-line x #FileOpen)
        ) ;_ foreach
        (close #FileOpen)
        T
 ) ;_ cond
) ;_ defun
;;; Copy entire contents of folder to new folder (No Subfolders)
;;; #Source - source directory of files to copy (subfolders excluded)
;;; #Destination - destination for copied files (created if doesn't exist)
;;; Alan J. Thompson, 05.12.09
(defun AT:CopyDirectoryFiles (#Source #Destination)
 (and (findfile #Source)
      (or (findfile #Destination) (vl-mkdir #Destination))
                 (vl-file-copy (strcat #Source "\\" x)
                               (strcat #Destination "\\" x)
                 ) ;_ vl-file-copy
               ) ;_ lambda
              (cddr (vl-directory-files #Source))
      ) ;_ mapcar
 ) ;_ and
) ;_ defun
;;; Copy entire contents of directory to new location (subfolders included)
;;; #Source - source folder to copy
;;; #Destination - destination directory (will be created if doesn't exist)
;;; Alan J. Thompson, 09.12.09
(defun AT:CopyDirectory (#Source #Destination)
      (startapp
        (strcat "xcopy " #Source " /E /H /Q /Y /I " #Destination)
      ) ;_ startapp
 ) ;_ and
) ;_ defun
;;; Parse Directory to List
;;; dir - Directory for parsing, such as (getvar "dwgprefix")
(defun AT:Directory->List (dir / dir l tdir i)
 (while (vl-string-search "/" dir)
   (setq dir (vl-string-subst "\\" "/" dir))
 ) ;_ while
 (or (eq "\\" (substr dir (strlen dir)))
     (setq dir (strcat dir "\\"))
 ) ;_ or
 (setq l (cons (substr dir 1 (vl-string-search "\\" dir 0)) l))
 (setq tdir (substr dir (+ 2 (vl-string-search "\\" dir 0))))
 (while (not (eq "" tdir))
   (setq
     l (cons (substr tdir 1 (setq i (vl-string-search "\\" tdir 0)))
             l
       ) ;_ cons
   ) ;_ setq
   (setq tdir (substr tdir (+ 2 i)))
 ) ;_ while
 (reverse l)
) ;_ defun
;list select dialog
;create a temp DCL multi-select list dialog from provided list
;value is returned in list form, DCL file is deleted when finished
;example: (setq the_list (AT:listselect "This is my list title" "Select items to make a list" "25" "30" "true" (list "object 1" "object 2" "object 3"))
;if mytitle is longer than defined width, the width will be ignored and it will fit to title string
;if mylabel is longer than defined width, mylabel will be truncated
;myheight and mywidth must be strings, not numbers
;mymultiselect must either be "true" or "false" (true for multi, false for single)
;created by: alan thompson, 9.23.08
;some coding borrowed from http://www.jefferypsanders.com (thanks for the DCL examples)
(defun AT:ListSelect  ( mytitle       ;title for dialog box
           mylabel       ;label right above list box
           myheight      ;height of dialog box !!*MUST BE STRING*!!
           mywidth       ;width of dialog box !!*MUST BE STRING*!!
           mymultiselect ;"true" for multiselect, "false" for single select
           mylist        ;list to display in list box
           / retlist readlist count item savevars fn fo valuestr dcl_id )
(defun saveVars(/ readlist count item)
 (setq retList(list))
 (setq readlist(get_tile "mylist"))
 (setq count 1)
 (while (setq item (read readlist))
   (setq retlist(append retList (list (nth item myList))))
   (while
     (and
       (/= " " (substr readlist count 1))
       (/= ""   (substr readlist count 1))
     (setq count (1+ count))
   (setq readlist (substr readlist count))
);defun
(setq fn (vl-filename-mktemp "" "" ".dcl"))
(setq fo (open fn "w"))
(setq valuestr (strcat "value = \"" mytitle "\";"))
(write-line (strcat "list_select : dialog {
           label = \"" mytitle "\";") fo)
(write-line
(strcat "          : column {
           : row {
             : boxed_column {
              : list_box {
                 label =\"" mylabel "\";
                 key = \"mylist\";
                 allow_accept = true;
                 height = " myheight ";
                 width = " mywidth ";
                 multiple_select = " mymultiselect ";
                 fixed_width_font = false;
                 value = \"0\";
           : row {
             : boxed_row {
               : button {
                 key = \"accept\";
                 label = \" Okay \";
                 is_default = true;
               : button {
                 key = \"cancel\";
                 label = \" Cancel \";
                 is_default = false;
                 is_cancel = true;
}") fo)
(close fo)
(setq dcl_id (load_dialog fn))
(new_dialog "list_select" dcl_id)
 (start_list "mylist" 3)
 (mapcar 'add_list myList)
 (end_list)
 (action_tile "cancel" "(setq ddiag 1)(done_dialog)")
 (action_tile "accept" "(setq ddiag 2)(saveVars)(done_dialog)")
 (start_dialog)
 (if (= ddiag 1)
    (setq retlist nil)
(unload_dialog dcl_id)
(vl-file-delete fn)
retlist
);defun
  • Like 2
;;; Getstring Dialog Box
;;; #Title - Title of dialog box
;;; #Default - Default string within edit box
;;; Alan J. Thompson, 08.25.09
(defun AT:GetString
      (#Title #Default / #FileName #FileOpen #DclID #NewString)
 (setq #FileName (vl-filename-mktemp "" "" ".dcl")
       #FileOpen (open #FileName "W")
 ) ;_ setq
 (foreach x '("TempEditBox : dialog {" "key = \"Title\";"
              "label = \"\";" "initial_focus = \"Edit\";" "spacer;"
              ": row {" ": column {" "alignment = centered;"
              "fixed_width = true;" ": text {" "label = \"\";" "}" "}"
              ": edit_box {" "key = \"Edit\";" "allow_accept = true;"
              "edit_width = 40;" "fixed_width = true;" "}" "}"
              "spacer;" ": row {" "fixed_width = true;"
              "alignment = centered;" ": ok_button {" "width = 11;" "}"
              ": cancel_button {" "width = 11;" "}" "}" "}//"
 ) ;_ foreach
 (close #FileOpen)
 (setq #DclID (load_dialog #FileName))
 (new_dialog "TempEditBox" #DclID)
 (set_tile "Title" #Title)
 (set_tile "Edit" #Default)
 (action_tile
   "accept"
   "(setq #NewString (get_tile \"Edit\"))(done_dialog)"
 ) ;_ action_tile
 (action_tile "cancel" "(done_dialog)")
 (start_dialog)
 (unload_dialog #DclID)
 (vl-file-delete #FileName)
 #NewString
) ;_ defun
  • Thanks 1
;;; Edit text box (Old Mtext editor)
;;; Returns typed in textstring
;;; Alan J. Thompson, 09.18.09
(defun AT:EditTextBox (/ *error* #Cmdecho #Mtexted #Mtext #String)
 (setq *error*  (lambda (msg)
                  (and #Mtext (entdel #Mtext))
                  (and #Cmdecho (setvar "cmdecho" #Cmdecho))
                  (and #Mtexted (setvar "mtexted" #Mtexted))
                ) ;_ lambda
       #Cmdecho (getvar "cmdecho")
       #Mtexted (getvar "mtexted")
 ) ;_ setq
 (setvar "cmdecho" 0)
 (vl-catch-all-apply 'setvar (list "mtexted" "OldEditor"))
 (setq #Mtext (entmakex (list
                          '(0 . "MTEXT")
                          '(100 . "AcDbEntity")
                          '(100 . "AcDbMText")
                          (cons 10 (trans (cadr (grread t 4 4)) 1 0))
                        ) ;_ list
              ) ;_ entmakex
 ) ;_ setq
 (vl-cmdf "_.mtedit" #Mtext)
 (setq #String (vla-get-textstring (vlax-ename->vla-object #Mtext)))
 (*error* nil)
 (if (/= #String "")
   #String
 ) ;_ if
) ;_ defun
;;; Return List of Layers
;;; created: Alan J. Thompson 3.2.09
(defun AT:LayerList (/ search names)
 (while
   (setq search (tblnext "layer" (null search)))
   (setq names (cons (cdr (assoc 2 search)) names))
 );while
   (setq names (acad_strlsort names))
);defun
;;; Layer On Routine
(defun AT:LayerOn (layer / ent color )
(if (setq ent (entget (tblobjname "layer" layer)))
    (setq color (assoc 62 ent))
    (entmod (subst (cons 62 (abs (cdr color))) color ent))
   );progn
);if
);defun
 ;; Layer Freeze Routine
 (defun AT:LayerFreeze (layer / ent frz? lay0 frz?0)
   (if (setq ent (entget (tblobjname "LAYER" layer)))
       (setq frz? (assoc 70 ent))
       (if (= (cdr (assoc 2 ent))
              (getvar "clayer")
           ) ;_ =
           (setq lay0 (entget (tblobjname "LAYER" "0")))
           (setq frz?0 (assoc 70 lay0))
           (entmod (subst (cons 70 0) frz?0 lay0))
           (setvar "clayer" "0")
         ) ;progn
       ) ;if
       (entmod (subst (cons 70 1) frz? ent))
     ) ;progn
   ) ;if
 ) ;_ defun
;;; Layer Off Routine
(defun AT:LayerOff (layer / ent color )
    (entmod (subst (cons 62 (- (abs (cdr color)))) color ent))
   );progn
);if
);defun
;;; Layer Set Routine
(defun AT:LayerSet ( layer / ent frz? color )
   (entmod (subst (cons 70 0) frz? ent))
   (setvar "clayer" layer)
  );progn
);if
);defun
;;; Create list of layer objects in drawing (excluding frozen)
;;; Alan J. Thompson, 04.16.09
 (defun AT:LayerListNoFreeze (/ #Layers #List)
   (setq #Layers (vla-get-Layers
                   (vla-get-activedocument
                   ) ;_ vla-get-activedocument
                 ) ;_ vla-get-Layers
   ) ;_ setq
   (vlax-for x #Layers
     (if (eq (vla-get-Freeze x) :vlax-false)
       (setq #List (cons x #List))
     ) ;_ if
   ) ;_ vlax-for
   (vlax-release-object #Layers)
   #List
 ) ;_ defun
;;; Invert On/Off state of Vla layer object
 (defun AT:LayerInvertOnOff (#LayerObj)
   (if (eq (vla-get-LayerOn #LayerObj)
           :vlax-true
       ) ;_ eq
     (vla-put-LayerOn #LayerObj :vlax-false)
     (vla-put-LayerOn #LayerObj :vlax-true)
   ) ;_ if
 ) ;_ defun
;;; Create list of layer objects in drawing (turned off)
 (defun AT:LayerListOff (/ #Layers #List)
                 ) ;_ vla-get-Layers
   ) ;_ setq
   (vlax-for x #Layers
     (if (eq (vla-get-LayerOn x) :vlax-false)
     ) ;_ if
   ) ;_ vlax-for
   #List
 ) ;_ defun
;;; Create a list of layers in drawing (excluding Xrefs)
;;; #Names - If T will give list of names, nil list of
;;;          vla layer objects
(defun AT:LayerListNoXref (#Names / #Layers #List)
               ) ;_ vla-get-Layers
 ) ;_ setq
 (vlax-for x #Layers
   (if (not (wcmatch (vla-get-name x) "*|*"))
     (setq #List (cons (if #Names
                         (vla-get-name x)
                         x
                       ) ;_ if
                       #List
                 ) ;_ cons
     ) ;_ setq
   ) ;_ if
 ) ;_ vlax-for
 (if #Names
   (vl-sort #List '<)
   #List
 ) ;_ if
) ;_ defun
;;; Convert existing layer to VLA-Object
;;; #Layer - name of layer
;;; Alan J. Thompson, 05.07.09
(defun AT:LayerObj (#Layer / #Obj)
 (and (tblsearch "layer" #Layer)
      (setq #Obj (vla-item (vla-get-Layers
                           ) ;_ vla-get-Layers
                           #Layer
                 ) ;_ vla-item
      ) ;_ setq
 ) ;_ and
 #Obj
) ;_ defun
;;; Create list of frozen layer objects in drawing
;;; Alan J. Thompson, 06.08.09
 (defun AT:LayerListFrozen (/ #Layers #List)
                 ) ;_ vla-get-Layers
   ) ;_ setq
   (vlax-for x #Layers
     (if (eq (vla-get-Freeze x) :vlax-true)
     ) ;_ if
   ) ;_ vlax-for
   #List
 ) ;_ defun
;;; Thaw specified layer object
;;; #LayerObj - vla layer object
(defun AT:LayerObjThaw (#LayerObj)
 (and (eq (type #LayerObj) 'VLA-OBJECT)
      (vl-catch-all-apply
        '(lambda () (vla-put-freeze #LayerObj :vlax-false) T)
      ) ;_ vl-catch-all-apply
 ) ;_ and
) ;_ defun
;;; List of layer objects
;;; Alan J. Thompson, 06.02.09
(defun AT:LayerObjList (/ #List)
 (vlax-for x (vla-get-Layers
             ) ;_ vla-get-Layers
 ) ;_ vlax-for
 #List
) ;_ defun
;;; Turn off specified layer object
;;; #LayerObj - vla layer object to turn off
(defun AT:LayerObjOff (#LayerObj)
      (vl-catch-all-apply
        '(lambda () (vla-put-layeron #LayerObj :vlax-false) T)
 ) ;_ and
) ;_ defun
;;; Turn on specified layer object
;;; #LayerObj - vla layer object to turn on
(defun AT:LayerObjOn (#LayerObj)
      (vl-catch-all-apply
        '(lambda () (vla-put-layeron #LayerObj :vlax-true) T)
 ) ;_ and
) ;_ defun
;;; Delete all objects on and purge specified layer
;;; #LayerName - Layername to delete and purge
;;; Alan J. Thompson, 09.19.09
(defun AT:LayerNuke (#LayerName / #Layers #Layer #SS)
 (setq #Layers (vla-get-layers
               ) ;_ vla-get-layers
 ) ;_ setq
 (if (tblsearch "layer" #LayerName)
     (setq #Layer (vla-item #Layers #LayerName))
     (or (not (eq (getvar "clayer") #LayerName))
           (vla-put-freeze (vla-item #Layers "0") :vlax-false)
         ) ;_ progn
     ) ;_ or
     (vla-put-freeze #Layer :vlax-false)
     (vla-put-lock #Layer :vlax-false)
     (and (setq #SS (ssget "_X" (list (cons 8 #LayerName))))
          (mapcar
            '(lambda (x) (vla-delete (vlax-ename->vla-object (cadr x))))
            (ssnamex #SS)
          ) ;_ mapcar
     ) ;_ and
     (not (vla-delete #Layer))
   ) ;_ progn
 ) ;_ if
) ;_ defun
  • Thanks 1
Similar to vl-position, but it will return ALL, not just first.
;;; Search list for matching value, returns list of nth count locations
;;; #Value - value to search list for
;;; #List - list to search
;;; Alan J. Thompson, 06.16.09
(defun AT:ListSearch (#Value #List / #Count)
 (setq #Count -1)
 (vl-remove-if
   'null
              (setq #Count (1+ #Count))
              (if (eq #Value x)
                #Count
              ) ;_ if
            ) ;_ lambda
           #List
   ) ;_ mapcar
 ) ;_ vl-remove-if
) ;_ defun
  • Thanks 1
;;; Remove nth item from list
;;; #Nth - nth number in list to remove
;;; #List - list to process
(defun AT:NthRemove (#Nth #List / #Index)
 (setq #Index -1)
 (vl-remove-if
   '(lambda (x) (eq #Nth (setq #Index (1+ #Index))))
   #List
 ) ;_ vl-remove-if
) ;_ defun
  • Thanks 1
;;; Replace nth item in list
;;; #Nth - nth number in list to replace
;;; #New - replacement item
(defun AT:NthReplace (#Nth #New #List / #Count)
 (setq #Count -1)
            (if (eq #Nth (setq #Count (1+ #Count)))
              #New
              x
            ) ;_ if
          ) ;_ lambda
         #List
 ) ;_ mapcar
) ;_ defun
;;; Convert all values in list and sublists to positive numbers
;;; #List - list with values to convert
;;; Alan J. Thompson, 06.14.09
(defun AT:AbsList (#List)
 (mapcar
   '(lambda (x)
      (cond
        ((vl-consp x) (AT:AbsList x))
        ((member (type x) (list 'INT 'REAL)) (abs x))
        (T x)
      ) ;_ cond
    ) ;_ lambda
   #List
 ) ;_ mapcar
) ;_ defun
  • Thanks 1
