Right click to copy selection has disapperaed
When I have selected objects in the drawing and right click - I no longer have the copy option. I need to take some objects from one dwg to another - how can i get this shortcut back.
Autocad 2006:huh:
You have a few options. You can select your objects, go to the 'Edit' pull down menu, and select copy & do the same for paste. You can also select your objects, and press 'CTRL+C', then 'CTRL+V' to paste. You can also save the item as a block and insert it into a drawing.
You might check out 'OPTIONS', go to the 'User Preference' tab, then look in the seciton for 'Right-Click Customization', to fix the right click menu.
