How Can I Convert Planar Surface To 3d Mesh.
Can You Please Explain More
Export the Plansurf-object using the 3DSOUT-command into a file - say TEMP.3ds
Open a new Drawing. Use the 3DSIN-command to import the TEMP.3ds
So you'll get a "AcDbPolyFaceMesh"
In case of problems contact me via http://www.black-cad.de
Regards
Jochen
i using autocad 2007 and the command 3dsout don't give my any result
Mr Scj, First I Want Tell You Thanks Alot For Your Usefull Help, Second, I Do What You Say Exactelly But When I Import The File Its Shape Change As You Will See In Attached Files How Can I Solve This Please? Thanks Again.
1.dwg
2.dwg
I Cann't Go To This Site Because It Lock By Security System In My Work. CAN YOU HELP ME HERE?
  • 3 weeks later...
the forum rules are that you only post your question once Mr Man
I'm deleting the duplicates of this thread :thumbsup:
ok, iam sorry i forget this rule. sorry again
  • 2 months later...
in my attachment drawing no. (1) refer to planar surface which i make by click on pline object and area into this pline divide as shown in drawing MY QUESTION IS
IS THERE ANY WAY TO MAKE 3D--MESH COMMAND LOOK LIKE PLANAR SURFACE SO JUST I CLICK ON A PLINE OBJECT AND THEN THE AREA INTO THIS PLINE DIVIDE AS MESHS?
Any One Have Any Idea For This Problem
No Answer Until Now Is It Very Difficult?
