I have a dynamic block of metal decking. Since you can't mirror in a DB I would like to array the two halves of the block at 12" (each half is 6" long). I want to array so that I can have one half array at each 6" increment. The problem I am having is that I can only get boths halves to appear at every 12". Any help here would be great!
I have attached my DB.
Metal Decking.dwg
I can't remember exactly how I have done this and my block is at work, however..
I either used 2 12" stretches, one with its base point 6" behind the other one
or 2 distance parameters, one 6" behind the other but included in the stretch action. Then 2 array actions, one on each distance parameter.
Hope that gives you some clues - or somebody with a better solution breezes past and we both learn something.
