AQucsaiJr Posted September 25, 2009 Posted September 25, 2009 I have made a menu in a CUI that I need everyone in the office to have access to. I placed the CUI file and all the commands and icon images it calls out and needs on the network hard drive that everyone has access to. I then placed this folder in the Support File Search Path on all the computers in the network, and loaded the CUI through the Customize User Interface. I had it work perfectly fine when it was tested on my computer and two other computers on the network. I had our network admin apply read-only permissions to it so that I was the only computer on the network that could change the file and sub folders within the file. Now nobody, including myself can use it. The CUI loads fine but reads, (Read Only), and the menu does not show up. Can I not give this file read only permissions, or is there something else going on here? Quote
alanjt Posted September 25, 2009 Posted September 25, 2009 I have a few menus I like to have loaded for us. The .cui is read-only and available on the network. I call it in our acaddoc.lsp with this: (defun CESMenu (/) (and (not (menugroup "CES-Custom")) (findfile "S:\\CADD Standards\\CES Custom CUI\\CES-Custom.cui") (command "_.menuload" "S:\\CADD Standards\\CES Custom CUI\\CES-Custom.cui") ) ;_ and (and (menugroup "CES-Custom") (menucmd "p30=+CES-Custom.POP1") ) ;_ and ) ;_ defun Quote
AQucsaiJr Posted September 25, 2009 Author Posted September 25, 2009 Couple questions for ya: 1) do you have to have two slashes when calling out the path? " \\ " 2) what do I change the menugroup and menucmd to? My file is PGE_CUI.cui, so would I make the menugroup "PGE_CUI"? But what do I put for the menucmd because I don't have any files labled PGE_CUI.POP1 in the folder anywhere? Quote
alanjt Posted September 25, 2009 Posted September 25, 2009 Couple questions for ya:1) do you have to have two slashes when calling out the path? " \\ " 2) what do I change the menugroup and menucmd to? My file is PGE_CUI.cui, so would I make the menugroup "PGE_CUI"? But what do I put for the menucmd because I don't have any files labled PGE_CUI.POP1 in the folder anywhere? 1) Either double \\ or single /. 2) Change it to whatever your menugroup is called. When you have it loaded on your computer, in the CUI editor, whatever name shows up. 3) Same as above, make it your menugroup name. It's not a separate file, POP1 are the menu pulldowns (they won't autoload). Quote
AQucsaiJr Posted September 25, 2009 Author Posted September 25, 2009 1) Either double \\ or single /.2) Change it to whatever your menugroup is called. When you have it loaded on your computer, in the CUI editor, whatever name shows up. 3) Same as above, make it your menugroup name. It's not a separate file, POP1 are the menu pulldowns (they won't autoload). This is whats in my ACADDOC.lsp file: (defun CESMenu (/) (and (not (menugroup "CES-Custom")) (findfile "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui") (command "_.menuload" "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui") ) ;_ and (and (menugroup "PGE_CUI") (menucmd "p30=+PGE_CUI.POP1") ) ;_ and ) ;_ defun (command "snap" "1/32") (command "-plotstamp" "on" "") I get this on the command line: Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: EXPRESS Customization file loaded successfully. Customization Group: RELAY Regenerating model. AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. AutoCAD Bonus Layer Tools Loaded. AutoCAD menu utilities loaded.snap Specify snap spacing or [ON/OFF/Aspect/Style/Type] <0.5000>: 1/32 -plotstamp Enter an option [On/OFF/Fields/User Fields/Log file/LOCation/Text Properties/UNits] : on Enter an option [On/OFF/Fields/User Fields/Log file/LOCation/Text Properties/UNits] : No unreferenced blocks found. No unreferenced blocks found. No unreferenced blocks found. No unreferenced blocks found. No unreferenced blocks found. Enter name of customization file to load: Command: *Cancel* Command: COMMANDLINE The CUI is not loading. I seem to be missing something. Could it be the path being called out wrong? the actual path to the CUI is: W:\AutoCAD\PGE_CUI\PGE_CUI.cui Quote
alanjt Posted September 25, 2009 Posted September 25, 2009 Change to this: (defun [color=Red]PGEMenu[/color] (/) (and (not (menugroup "[color=Red]PGE_CUI[/color]")) (findfile "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui") (command "_.menuload" "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui") ) ;_ and (and (menugroup "PGE_CUI") (menucmd "p30=+PGE_CUI.POP1") ) ;_ and ) ;_ defun [color=Red](PGEMenu)[/color] You have to also call the command (the last line in red). Quote
AQucsaiJr Posted September 25, 2009 Author Posted September 25, 2009 Crap... I totally skipped over that when I looked at it. Thanks... That seems to work perfect. Quote
alanjt Posted September 25, 2009 Posted September 25, 2009 Crap... I totally skipped over that when I looked at it. Thanks... That seems to work perfect. Glad you got it to function. If you need any further help, don't hesitate to ask. Quote
AQucsaiJr Posted September 25, 2009 Author Posted September 25, 2009 No problem.... Thanks Much! Quote
Lee Mac Posted September 25, 2009 Posted September 25, 2009 Another method, avoiding the command line call: (defun PGEMenu ( ) (vl-load-com) (or (menugroup "PGE_CUI") (and (findfile "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui") (vla-load (vla-get-MenuGroups (vlax-get-acad-object)) "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui"))) (and (menugroup "PGE_CUI") (menucmd "p30=+PGE_CUI.POP1"))) (PGEMenu) Quote
alanjt Posted September 25, 2009 Posted September 25, 2009 Another method, avoiding the command line call: (defun PGEMenu ( ) (vl-load-com) (or (menugroup "PGE_CUI") (and (findfile "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui") (vla-load (vla-get-MenuGroups (vlax-get-acad-object)) "W:\\AutoCAD\\PGE_CUI\\PGE_CUI.cui"))) (and (menugroup "PGE_CUI") (menucmd "p30=+PGE_CUI.POP1"))) (PGEMenu) And, of course, the vla-method. Sadly, I put this together long before I started using VLisp. This is the first time I've looked at that code since I wrote it. Quote
AQucsaiJr Posted September 25, 2009 Author Posted September 25, 2009 Dang it Lee..... As soon as I get it working you throw in a little different version... lol Thanks for the help guys. Quote
Lee Mac Posted September 26, 2009 Posted September 26, 2009 Dang it Lee..... As soon as I get it working you throw in a little different version... lolThanks for the help guys. ... ... Quote
