Thanks Cab... I'll try this version out... Any idea when you will have horizontal support ready?
  • Replies 28
  • AQucsaiJr
    15
  • CAB
    4
  • alanjt
    3
  • Lee Mac
    3
Cab this new LISP does not give any options for different alignment, such as center, left, right...etc. Unless I am missing something.
*I figured out how you designed the alignment process after messing around with it a little longer. I like this one... I think this might work for me, however is there a way to keep the spacing of the text the same, rather than have it change the spacing during the alignment?
I modified version 14 so download it again.
The default mode is changed to "No change in line spacing"
To alter the spacing option enter S at the Select master text prompt.
Corrected a bug too so download the new version.
Not enough interest in the Horizontal option to motivate me to add it.
Awesome... Thanks CAB... I'll give it a go and let you know if I find anything.
Will the link you provided me in post #20 get me to the latest version you have updated?
*Answered my own question.
I am getting an error with this one:
Command: at
Select master text. Verticaly aligned [V/H/Spacing] "H" change to Horrizontally:
Select Text to align with Master Text.
Select objects: Specify opposite corner: 7 found
Select objects:
Error: bad argument type: numberp: nil
Command:
*I think the error has to do with the none command in the spacing options because the previous version has the same error if none is selected for spacing.
I'll take a look in a few minutes. Doing a Windows update....
No rush... I took a look through it and could not see anything obvious, but I am just getting into LISP design so it is a little beyond me anyways.
That fixed the problem... It works perfect for vertical text... It aligns the text Horizontally perfectly fine, however the spacing is adjusted, but then again it is not designed for Horizontal alignment...
Thanks CAB... This will work great... I will keep a link to your post both here and the swamp in case horizontal is added somewhere down the road.
