When im working fast, switching between internal Autocad windows, auto cad crashes quite often, i looked in the windows task manager to see Autocad is using 410,000K in memory usage, is this normal, the file im working on is 12mb
THANKS IN ADVANCE
DIZZY
I have ran into this quite often using 32 bit operating system. When using 64 bit I do not find it to be a problem.
Are you sure it is not a hardware problem? What are the specs for your computer? How much physical RAM do you have onboard?
