workspace editing and sheet sets
Hi everyone. New to AutoCAD 2010 and just had a couple of questions. Was wondering how (if possible/necessary) i'd go about changing the dimensions of my workspace, and also, what are sheet sets and how do i use them? thanks :) adam
I don't understand "dimensions of a workspace".
Sheet sets are used to organize sheets into "sets". You can also incorporate FIELDS into the sheets so that title block and other elements are edited in the sheet set (one place), rather than on every single sheet. Lastly, you can incorporate fields that refer to views on other sheets For example, if you have a note that says "See detail 3, Sheet 21" it can be dynamic so that if sheets are added, removed, moved, the note will update automatically so that the detail # and sheet # stay correct.
Haha ok i must be confused. I've only ever used AutoCAD classic at school and we have only used basics. But I'd always had to change the size of the space i would be drawing in when i started. But thanks :)
Well, the definition of a "workspace" in AutoCAD is more or less the layout of the UI. In other words, of all the components such as the Ribbon, palettes, toolbars, etc. -- what is displayed and where.
Ok well thanks again. Still learning the terminology. Picking stuff up as i go :)
