about OFFSET command : erase source/layer settings
I would like to ask about the "offset" command, there are options of "erase source" "Layer".
I wonder if there is any system variables which store those settings. For I would like to make an AutoLisp command which toggles on/off of "erase source" or even to specify offset layer.
Thank you
Thank you for the suggestion, but what I am looking for is the system variables (or something else) to control these. For example "trimmode" is to control the "trim" command, so that I can make an Autolisp command to toggle "trimmode" between 1 and 0.
Good question, the only sys Vars that come to mind with the OFFSET command are:
OFFSETDIST & OFFSETGAPTYPE
But I shall do a bit of digging for you :)
Express-Tools
Exoffset.lsp …
(setq dist (acet-exOffset-get-dist)
lay (xstrcase (acet-exOffset-get-layermode))
gap (getvar "offsetgaptype") acet-setvar….
Express-Tools
Exoffset.lsp …
Thanks for the advise....wonder if I can do this in Lisp (instead of VLisp) for I am not familiar with VLips !!
Hausta refers to the Express Tools ExOffset.lsp which can be found in the Express tools folder - this saves the modes in the drawing using such functions as:
Which are defined in the above .lsp file. These functions in turn use:
(acet-setvar)
To store the relevant settings.
These are Express Tools functions, not VLISP :)
