Hi all
While relaxing with the autocad help I discovered the following two commands that if you don't know them already should blow your mind
1 Co ord filter: when you're about to select a point enter '.' and x,y or z respectively and choose a point you will be prompted to select another point this point will define the axis you haven't yet defined e.g .x second point defines y
2 FIND MID: similar to above while selecting a point enter 'mtp' and then select two points. This finds the centre point between any two points.
not exactly the correct board to post this in but I never seem to post in any other
Enjoy
Ollie
