-KarL- Posted September 28, 2009 Posted September 28, 2009 I am finally getting around to converting my programs over to VB.NET and I have been able to find a lot of sample code to help out but the one thing I can't figure out is inserting blocks. Anyone have any sample code I can look at to try to figure this out. Thanks, -KarL- Quote
gile Posted September 29, 2009 Posted September 29, 2009 Hi, You can have a look at this tutorial: http://images.autodesk.com/adsk/files/autocad_2007_.net_training.zip or here: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/index.html Quote
-KarL- Posted October 5, 2009 Author Posted October 5, 2009 I have been using the autodesk site link a lot already, but haven't found anything on inserting blocks, unless I am looking in the wrong spot. Quote
gile Posted October 5, 2009 Posted October 5, 2009 Here's a little sample (C#, sorry, but quite easy to translate) using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; namespace BlockInsertion { public class Class1 { [CommandMethod("Test")] public void Test() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; // Get the block name PromptStringOptions pso = new PromptStringOptions("\nEnter block name: "); PromptResult pr = ed.GetString(pso); if (pr.Status == PromptStatus.OK) { // Start a transaction using (Transaction tr = db.TransactionManager.StartTransaction()) { // Test if block exists in the block table BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); if (!bt.Has(pr.StringResult)) { ed.WriteMessage("\nBlock not found."); } else { ObjectId id = bt[pr.StringResult]; // Get insertion point PromptPointOptions ppo = new PromptPointOptions("\nSpecify insertion point: "); PromptPointResult ppr = ed.GetPoint(ppo); if (ppr.Status == PromptStatus.OK) { Point3d pt = ppr.Value.TransformBy(ed.CurrentUserCoordinateSystem); // Create a block reference BlockReference br = new BlockReference(pt, id); // Get Model space BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[blockTableRecord.ModelSpace], OpenMode.ForWrite); // Add the block reference to Model space btr.AppendEntity(br); tr.AddNewlyCreatedDBObject(br, true); } } // Commit the transaction tr.Commit(); } } } } } Quote
gile Posted October 5, 2009 Posted October 5, 2009 The same one using a Jig. using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; namespace BlockInsertion { class BlockJig : EntityJig { Point3d pt; public BlockJig(BlockReference br) : base(br) { pt = br.Position; } protected override SamplerStatus Sampler(JigPrompts prompts) { JigPromptPointOptions jpo = new JigPromptPointOptions("\nInsertion point: "); jpo.UserInputControls = UserInputControls.Accept3dCoordinates; PromptPointResult ppr = prompts.AcquirePoint(jpo); if (ppr.Status == PromptStatus.OK) { if (pt == ppr.Value) { return SamplerStatus.NoChange; } else { pt = ppr.Value; return SamplerStatus.OK; } } return SamplerStatus.Cancel; } protected override bool Update() { ((BlockReference)Entity).Position = pt; return true; } } public class TestCommand { [CommandMethod("Test")] public void Test() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; PromptStringOptions pso = new PromptStringOptions("\nEnter block name: "); PromptResult pr = ed.GetString(pso); if (pr.Status == PromptStatus.OK) { using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); if (!bt.Has(pr.StringResult)) { ed.WriteMessage("\nBlock not found."); } else { ObjectId id = bt[pr.StringResult]; BlockReference br = new BlockReference(new Point3d(0.0, 0.0, 0.0), id); BlockJig bJig = new BlockJig(br); pr = ed.Drag(bJig); if (pr.Status == PromptStatus.OK) { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[blockTableRecord.ModelSpace], OpenMode.ForWrite); btr.AppendEntity(br); tr.AddNewlyCreatedDBObject(br, true); } } tr.Commit(); } } } } } Quote
-KarL- Posted October 8, 2009 Author Posted October 8, 2009 Any chance you can translate this into VB code? ObjectId id = bt[pr.StringResult]; I think that is where I am having the problem Thanks for the help so far -KarL- Quote
gile Posted October 8, 2009 Posted October 8, 2009 Any chance you can translate this into VB code? ObjectId id = bt[pr.StringResult]; I think that is where I am having the problem Thanks for the help so far -KarL- Dim id As ObjectId = bt(pr.StringResult) Or (maybe more explicit): Dim blockName As string = pr.StringResult Dim id As ObjectId = bt(blockName) Quote
xdbk07 Posted February 28, 2013 Posted February 28, 2013 Hi gile, I want to select block by click it and replace some attribute value (using Jig). Please let me know how to do? Thanks, Quote
