hi guys i have a problem i want render a image in axonometric projection specially in "dimetric trimetric".i i find this http://www.compuphase.com/axometr.htm#NEN2536 but has only axonometric isometric.if anyone know can explain me how work.i mean what angle(x,y,z) i must put on the camera setting.thanks
Why not use the angles in the link I gave you? They appear to be arbitrary anyway.
these angles are the angles between the axes,i want put the point of view(camera,eye)i must put the camera in the right place and then have these angles
Have you tried positioning the camera using the options in the Camera command?
yes but there is the same problem,anyway thanks
Do you know the angles you want to duplicate with the camera? Can a point (X,Y & Z) be established within the drawing at which the camera can then be positioned?
  • 2 years later...
Hi, I'm currently looking the same tool for actual axonometric projection, with custom angles between the axis, etc...
Were you able to find anything?
  • 7 months later...
in autocad's command line tipe "ddvpoint" .the angles are 330 from the x axis and 75 from the xy plane. the will give you a 30\60 axonometric view.
hope you find this useful
Mohammad Khawajah
Amman, Jordan
