pov Posted July 3, 2008 Share Posted July 3, 2008 hi guys i have a problem i want render a image in axonometric projection specially in "dimetric trimetric".i i find this http://www.compuphase.com/axometr.htm#NEN2536 but has only axonometric isometric.if anyone know can explain me how work.i mean what angle(x,y,z) i must put on the camera setting.thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 3, 2008 Share Posted July 3, 2008 A simple explanation of trimetric projection: http://www.ul.ie/~rynnet/keanea/trimetri.htm Sounds like you have your work cut out for you. Good luck. Quote Link to comment Share on other sites More sharing options...
pov Posted July 3, 2008 Author Share Posted July 3, 2008 i know how work in paper but if u want put one camera u must put some angles on the camera take an example and see what i mean http://www.pixelpilot.dk/isometric.htm Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 3, 2008 Share Posted July 3, 2008 Why not use the angles in the link I gave you? They appear to be arbitrary anyway. Quote Link to comment Share on other sites More sharing options...
pov Posted July 3, 2008 Author Share Posted July 3, 2008 these angles are the angles between the axes,i want put the point of view(camera,eye)i must put the camera in the right place and then have these angles Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 3, 2008 Share Posted July 3, 2008 Have you tried positioning the camera using the options in the Camera command? Quote Link to comment Share on other sites More sharing options...
pov Posted July 3, 2008 Author Share Posted July 3, 2008 yes but there is the same problem,anyway thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 3, 2008 Share Posted July 3, 2008 Do you know the angles you want to duplicate with the camera? Can a point (X,Y & Z) be established within the drawing at which the camera can then be positioned? Quote Link to comment Share on other sites More sharing options...
nicofirk Posted September 17, 2010 Share Posted September 17, 2010 hi guys i have a problem i want render a image in axonometric projection specially in "dimetric trimetric".i i find this http://www.compuphase.com/axometr.htm#NEN2536 but has only axonometric isometric.if anyone know can explain me how work.i mean what angle(x,y,z) i must put on the camera setting.thanks Hi, I'm currently looking the same tool for actual axonometric projection, with custom angles between the axis, etc... Were you able to find anything? Quote Link to comment Share on other sites More sharing options...
Khawajah Posted May 7, 2011 Share Posted May 7, 2011 Hi, I'm currently looking the same tool for actual axonometric projection, with custom angles between the axis, etc...Were you able to find anything? in autocad's command line tipe "ddvpoint" .the angles are 330 from the x axis and 75 from the xy plane. the will give you a 30\60 axonometric view. hope you find this useful Mohammad Khawajah Amman, Jordan Quote Link to comment Share on other sites More sharing options...
