any one can help to write a lisp to pick attribute and change it to text with same value
thanks
its in express menu
Express>Blocks>Explodes blocks to text.
Command: Burst
I believe the correct definition for the Burst command is that it explodes attributes to text and not blocks. I totally agree this appears to be the most logical approach.
motee-z: What version of AutoCAD are you using?
burst command is active when attribute attached with block but when attribute is not attached with block i mean single the command became not active also from express tools, i use autocad 2008
thanks
I think this I you are looking for:
(defun c:AtoT( / theAttributeEntity AttributeList TextList )
(if (not (setq theAttributeEntity (car (entsel "\nSelect attribute to convert to text: ")))) (exit))
(setq AttributeList (entget theAttributeEntity)
      TextList      (list '(0 . "TEXT")
                          '(100 . "AcDbEntity")
                          '(100 . "AcDbText")))
(foreach DXFCode '(7 8 10 11 40 41 50 51 67 71 72 210 410)
 (setq TextList (append TextList (list (assoc DXFCode AttributeList))))
                       (list (cons '1  (cdr (assoc 2  AttributeList))))
                       (list (cons '73 (cdr (assoc 74 AttributeList))))))
(entdel theAttributeEntity)
(entmake TextList)
Regards,
