Vaughn Posted September 30, 2009 Posted September 30, 2009 Running Autocad LT 2006 - having problems with batting linetype not appearing in paper space and when printing. Linetype shows corrrectly when in model space. have re-loaded linetype , reset linetype scale but still have problem - any help would be much appreciated. Quote
ReMark Posted September 30, 2009 Posted September 30, 2009 What is the setting of PSLTSCALE at the moment? Quote
Vaughn Posted September 30, 2009 Author Posted September 30, 2009 i have gone around in circle a bit but have selected all and reset linetype to layer and linescale to 1. i have also made sure that the "use paper space units for scaling" box is checked. now my batting is (when adjusted to the correct depth for each batting line using properties) viewing correctly in paperspace but is wildly out in modelspace!! this will al least enable me to plot my drawings correctly but it would be nice to know where i have gone wrong for the next job! Quote
Afro Posted September 8, 2010 Posted September 8, 2010 Sorry to reiterate your porblem, however i am experiencing the same issue. my batting lines appear fine in model space but when it comes to scaled viewports it is all over the shop! I know anotative scales don't apply to lines, but i do not understand why the psltscale and the modelspace scale don't work. Surley i dont have to go through a trial and error to match my batting lines to models space and viewport? someone please give some advice, that isn't "set psltscale, Msltscale & lt scale to 1"....this unfortunatly doesn't work Quote
