navsegdaep Posted September 30, 2009 Posted September 30, 2009 I wrote a program that extract block attributes from the current drawing. And it worked fine. After upgrading the computer my code stopped working. In debugging mode I found the following problem: (partial code) Dim oEnt As AcadEntity For Each oEnt In ThisDrawing.ModelSpace (problem line) If TypeOf oEnt Is AcadBlockReference Then Set blkTitle = oEnt If blkTitle.Name = "Tag" And blkTitle.HasAttributes Then aryAttributes = blkTitle.GetAttributes shtObj.Cells(i + 1, 1) = aryAttributes(0).TextString i = i + 1 End If End If Next I'm getting ThisDrawing.ModelSpace = and on the next step ThisDrawing.ModelSpace = oEnt = Please advise me how to fix it. Quote
