I have 49 drawings which have the xref named x-392000-c103 and ai wanted to send the xref to the back with a script but cant seem to figure it out, or find anywhere that shows you how to select by xref name.
This drawing has multiple xrefs all on the same layer so i need to find a way to select by xref name rather then by layer.....
help please
Assuming you only have one instance of the xref, this should work:
(defun xrb (name / ss)
 (if (setq ss (ssget "_X" (list (cons 2 name))))
   (command "._draworder" (ssname ss 0) "" "back")
(xrb "x-392000-c103")
Ron, you could just send the selection set to draworder, or am I wrong?
(command "._draworder" ss "" "back")
Sorry for the Newbie questions, but is this a lisp? Cause i saved it in note pad as a lisp file, then appload, then typed in my command prompt 'xrb'
how do i run this?
thanks
You're probably right...but I did not test it :oops:
how do i run this?
thanks
One the lisp is loaded use this to run it:
this is the error I get
Command: (xrb "x-392000-c103")
Unknown command "BACK". Press F1 for help.
Give this one a whirl
*ron slaps own hand for using command call* :D
(defun xrb (name / doc e ms n o sorttbl ss xdic)
 (vl-load-com)
 (setq    xdic (vla-getextensiondictionary
          (setq ms    (vla-get-modelspace
             (setq doc (vla-get-activedocument (vlax-get-acad-object)))
 (if
   (vl-catch-all-error-p
     (setq sorttbl (vl-catch-all-apply 'vla-getobject (list xdic "ACAD_SORTENTS")))
    (setq sorttbl (vla-addobject xdic "ACAD_SORTENTS" "AcDbSortentsTable"))
 (setq n -1)
   (progn (while (setq e (ssname ss (setq n (1+ n))))
        (vlax-invoke sorttbl 'movetobottom (list (vlax-ename->vla-object e)))
      (vla-regen doc acallviewports)
 (vl-load-com)
 (if
 (setq n -1)
Still odd that it gave an error. I have 2 draw order macros I use daily (draw front and draw back) and I never have problems. with them.
Works great!!
Thanks Again Ron!
Glad you got it to work :)
