Stiff Posted September 30, 2009 Posted September 30, 2009 Hello everybody, I've downloaded the 2010 AutoCAD trial and changed the linetype of a line to a dashed one, though the line remains continious. I normally use AutoCAD 2007 and it always worked perfectly in that version. I'm pretty sure I'm not doing anything wrong in 2010, it should be as simple as choosing another linetype. Could anyone help me? Quote
rkmcswain Posted September 30, 2009 Posted September 30, 2009 Nothing has changed with regard to what you are doing. Most likely, the global linetype scale needs to be adjusted. The OOTB "dashed" linetype for example is defined as a line segment of "0.5 units" and a space of "0.25 units". So if your line is 40,000 units long, the dashes will be so short, you won't see them. With LTSCALE set to 1, draw a line 4 units long and assign it the "DASHED" linetype. What does it look like now?l (Make sure CELTSCALE = 1.0 also) Quote
Stiff Posted September 30, 2009 Author Posted September 30, 2009 Thank you very much, that did the trick. Quote
