Importing Layouts via Design Center
I'm sure many of you import layouts amongst other things from previous drawings quite often, (as I do) but I have never been able to figure out how to carry over the same layer state freezes. :? When you import it pending no block conflicts it will bring the layout exactly as it was in the other drawing with the viewport window(s) and everything. However it won't bring in the same layer freezes, even if those layers are the same and existing in the drawing they are brought into. And even if you copy and paste a viewport on the same layout it won't carry the same freezes over (in the same drawing). Any remedy for this problem? Thanks!8)
You could use Layer States - Save the one you need in an established dwg, export it, then import it when needed.
I'm not sure if it's possible to do this automatically with Design Center though.
