Exporting from Autodesk Map 3D 2007 to Mapinfo
Help
When using Autodesk Map 2004 I could export to a mid/mif file having assigned a co-ord sytem and it would go into the right place when I imported it into Mapinfo. I have now upgraded to 2007 and when I try to do the same thing the resulting Tab file is located somewhere in Outer Space. I have looked at the Mid/Mif File and it has been given Non Earth Co-ords. I have either missed a setting somewhere in AutoCAD or the co-ord conversion is not working. Has anyone had this problem and do they know how to solve it before I throw my PC out of the Window, and I am on the 11th Floor.
:x
