Ford Posted October 1, 2009 Posted October 1, 2009 I am Superhatching a block into a rectangle. I specify the insertion point then type 1 for x scale factor and 1 for y scale factor. Angle 0. The problem is that the block gets postioned way outside the rectangle, which is not correct. I have been trying to figure this out for hours now. Any help would be much appreciated. Thanks. Quote
ReMark Posted October 1, 2009 Posted October 1, 2009 Could it be that when the block was constructed the insertion point was not on the block itself? Maybe it is set to 0,0. Quote
Ford Posted October 1, 2009 Author Posted October 1, 2009 How do I check that? It worked on another superhatch. Quote
ReMark Posted October 1, 2009 Posted October 1, 2009 And how are you specifying the insertion point? Picking it or typing in coordinates? Quote
ReMark Posted October 1, 2009 Posted October 1, 2009 Two possible reasons for an insertion point to be off are wrong object snap and changing units. One possible solution. Open the block drawing itself and set the INSBASE variable to the desired position. Save it. Open drawing with rectangle in it and try the SuperHatch command again. Getting late. Gotta go. Been up since 3 a.m. Quote
