mien Posted October 4, 2009 Posted October 4, 2009 how can i set text style using VBA..now im set the text using this code. but it no work....thanks.. ThisDrawing.SendCommand "-style" & vbCr & "HDP_HYDRO" & vbCr & "romans" & vbCr & "0" & vbCr & "0.75" & vbCr & "15" & vbCr & "N" & vbCr & "N" & vbCr & "N" & vbCr i try to set text style for this text Set cllyr = ThisDrawing.Layers.Add("Level 1") cllyr.color = Val(cl1) Set point = ThisDrawing.ModelSpace.AddPoint(dblPt) point.Layer = "Level 1" 'convert sign value If optLand.Value = True Then strTemp = Round(arrText(2), acc) Set cllyr = ThisDrawing.Layers.Add("Level 1") cllyr.color = Val(cl1) Set actext = ThisDrawing.ModelSpace.AddText(Round(arrText(2), acc), dblPt, 2) actext.Alignment = acAlignmentCenter ElseIf optHydro.Value = True Then strTemp = Fix(arrText(2)) Set cllyr = ThisDrawing.Layers.Add("Level 1") cllyr.color = Val(cl1) Set actext = ThisDrawing.ModelSpace.AddText(Fix(-(arrText(2))), dblPt, 2) actext.ObliqueAngle = 15 actext.Alignment = acAlignmentRight End If actext.Rotation = 2 * pi actext.Layer = "Level 1" actext.TextAlignmentPoint = dblPt actext.Update If optHydro.Value = True Then strTemp = Right(arrText(2), 1) Set cllyr = ThisDrawing.Layers.Add("Level 1") cllyr.color = Val(cl1) Set actext = ThisDrawing.ModelSpace.AddText(Right(arrText(2), 1), dblPt, 1.5) actext.ObliqueAngle = 15 actext.Alignment = acAlignmentMiddleLeft actext.Rotation = 2 * pi actext.Layer = "Level 1" actext.TextAlignmentPoint = dblPt actext.Update End If Quote
