i am using autocad arch 2010 and facing these problems.
1. lag when orbiting
2. when im at press/pull + orbiting tool sometime autocad not responding then fatat error occurred..
it happened 3 times whithin an hour.
was it because im using vista?
inter core2 duo T7500 2.20GHz processor.. with 3G ram..
should be no problem with my specs rite?
Arch 2010 should run fine on Vista assuming your system meets the minimum required specs as suggested by AutoCAD. Don't assume that because your computer meets the minimum specs for running Vista you'll be able to run Arch 2010. AutoDesk specs are usually a little more roboust.
What is the file size of the drawing?
I believe the minimum cpu speed for 2010 products is 3GHz. You're a tad short.
One thing you can do, if your computer is lagging, is switch to Wireframe viewing mode before orbiting. This will ease the load on your processor and video card. By the way, you failed to mention what video card you have?
ATI mobility radeon HD 2400 XT
hahha..
i'll try to switch to wildframe..
LOL..
wildframe -.-
any all the way using wireframe to draw.
nv change to other view except applying material.
Wireframe is a visual style.
So you have a 500+MB drawing that you have applyied materials too when the problem occurs?
ya..
i keep applying materials while drawing..
