I know how to covert a DWG to a PDF individually but was wondering if there was a way to convert multiple DWG's to PDF's.
  • 2 weeks later...
You can set a template up to plot multiple DWG's using Sheet Set Manager to PDF. Otherwise you can look for a Batch Plot Lisp and try that route I think?
I either use AnyDwg (link above) or run a script and use the built in AutoCAD dwg>pdf "printer".
I publish to DWF format & then print from Design Review to a pdf maker (either Acrobat or CutePDF), works a treat & file size is quite small.
At my office we use a program called PDF redirect. I PDF and send out a lot of drawings and that program acts like a printer except it makes PDFs so I don't have to fiddle with opening other software. Its pretty much all automatic after you set up the plot.
I do the same. It works very well for us.
I also PDF my documents to clients on a regular basis, and I have found that cutePDF works very well. It works just like a printer.
  • 1 year later...
You can also use AutoDWG DWG to PDF converter. I always load CTB to convert into PDF with this converter.
