hi every one
i used autocad for design irrigation layout landscape and i want lisp for divide on line put i want insert blocks too i want change point by block to come easy way like that
smiles like blocks all segment same
plz help me in that
thx
Neither the Divide or Measure commands do what you want?
i mean by divide commend
div then enter then select object then block the name of block then number of segments
its long stebs
i want to learn how to make lisp or some one give me lisp of short way
thx for you
You can write a macro and have it pause for the name of the block and the number of segments. If the block name is always the same one, or a particular one you use often, create a macro specifically for it and have it pause only for the number of segments.
Forget what I said. See below. Alanjt is da bomb!
This is total garbage, but I had a few minutes to kill before time to go home and I was bored....
(defun c:DAC (/ ss point curve num dist lgth)
 (and
   (princ "\nSelect object(s) to divide along curve: ")
   (setq ss (ssget ":L"))
   (setq point (getpoint "\nBase point for objects: "))
   (setq curve (car (entsel "\nSelect curve to divide: ")))
   (wcmatch (cdr (assoc 0 (entget curve))) "LINE,LWPOLYLINE,ARC")
   (setq num (getint "\nNumber of objects: "))
   (setq num (1+ num))
   (setq dist 0.0)
   (or (not (vl-catch-all-error-p (setq lgth (vl-catch-all-apply 'vla-get-length (list (vlax-ename->vla-object curve))))))
       (not (vl-catch-all-error-p (setq lgth (vl-catch-all-apply 'vla-get-arclength (list (vlax-ename->vla-object curve))))))
   ;(setq lgth (vla-get-length (vlax-ename->vla-object curve)))
   (while (< dist (- lgth (/ lgth num)))
     (vl-cmdf "_.copy" ss "" point (vlax-curve-getpointatdist curve (setq dist (+ dist (/ lgth num)))))
   ) ;_ while
 ) ;_ and
) ;_ defun
hi
but i didnt know how to write macro thx
when i put this code thx
this what i can do
divide enter
select object to divide: I CAN SELECT LINE .PLINE.ARC.ect
enter the number of segments or {block}:block enter
enter name of block to insert : ir enter ( it will be fixed)
align block with object ? {yes/no} : yes enter
enter the number of segments: 10 enter (it will be changed )
thx
You don't have to write a macro just use the LISP routine alanjt wrote for you above. If you do not know how to use a LISP routine go to the CADTutor AutoCAD FAQ section of the forum and look under Customisation. Read the article entitled "How do I use an AutoLISP routine?".
hi
sorry remark
i did it, i convert it to lisp but alanjt didnt wrot code right it didnt give me any help just select objects and number and no block or name of block
did you know any way to help me to how can i write code what i want above
how you writ code?
i want lisp its ask me slect object like line or pline or ect and fixed block name and ask me about number only
thx for help
So you want a LISP routine and not a macro. I see. And you say you had a problem with alan"s code? The only thing I can do at the moment is download the lisp routine, run it on my computer and see what happens.
hi
sorry remark
how you writ code?
thx for help
I never said it would do what you wanted. I was just playing around and thought I would post it. However, what I posted could easily be modifed to insert a block instead of just copying selected objects. Why not give it a try yourself.
hi remark
hi alanjt
i tried by myself before but i didnt know the language of cods
thx alanjt
thx remark
did you know how can i found cods of lizp language
thx u
Start with the AutoLISP, VBA forum. There are several threads about good sources for LISP routines and writing code.
i got book
The
AutoLisp
Tutorials
Written and Compiled by Kenny Ramage
but i didnt found more function for help on it so i didnt konw
  • 7 months later...
Have you learned the lisps?
I did make this routines along time ago. Can send you again if you still need this didvide/ measure lisp.
TC
On a side note this is the origin of my CopyAlongCurve.LSP :wacko:
