gilsoto13 Posted October 7, 2009 Posted October 7, 2009 Hi Everyone.. thanks again for your constant support For those who are bored... I am gonna need very soon to adapt a lisp to wblock (extract) only selected blocks to a specified directory... I got this lisp from someone to wblock all blocks to a specified directory.. where can we change it to allow us to select blocks to wblock? About the rename lisp.. I found a search and replace for block names and an add preffix or suffix to block names.. that will do it for the moment... but this may help me to reduce my workload also... feel free to help. ; ---------------------------------------------------------------------- ; (Wblocks all local block definitions to target path) ; Copyright (C) 2000 DotSoft, All Rights Reserved ; Website: [url="http://www.dotsoft.com/"]http://www.dotsoft.com[/url] ; ---------------------------------------------------------------------- ; DISCLAIMER: DotSoft Disclaims any and all liability for any damages ; arising out of the use or operation, or inability to use the software. ; FURTHERMORE, User agrees to hold DotSoft harmless from such claims. ; DotSoft makes no warranty, either expressed or implied, as to the ; fitness of this product for a particular purpose. All materials are ; to be considered ‘as-is’, and use of this software should be ; considered as AT YOUR OWN RISK. ; ---------------------------------------------------------------------- (defun c:wba () (setq cmdecho (getvar "CMDECHO")) (setvar "CMDECHO" 0) ; (if (not dos_getdir) (setq path (getstring "\nDS> Target Folder: " T)) (setq path (dos_getdir "Target Folder" (getvar "DWGPREFIX"))) ) (if (/= path nil) (progn (if (= (substr path (strlen path) 1) "\\") (setq path (substr path 1 (1- (strlen path)))) ) (princ "\nDS> Building List of Blocks ... ") (setq lst nil) (setq itm (tblnext "BLOCK" T)) (while (/= itm nil) (setq nam (cdr (assoc 2 itm))) (setq pass T) (if (/= (cdr (assoc 1 itm)) nil) (setq pass nil) (progn (setq ctr 1) (repeat (strlen nam) (setq chk (substr nam ctr 1)) (if (or (= chk "*")(= chk "|")) (setq pass nil) ) (setq ctr (1+ ctr)) ) ) ) (if (= pass T) (setq lst (cons nam lst)) ) (setq itm (tblnext "BLOCK")) ) (setq lst (acad_strlsort lst)) (princ "Done.") ; (foreach blk lst (setq fn (strcat path (chr 92) blk)) (if (findfile (strcat fn ".dwg")) (command "_.WBLOCK" fn "_Y" blk) (command "_.WBLOCK" fn blk) ) ) ) ) ; (setvar "CMDECHO" cmdecho) (princ) ) Quote
