stockers Posted October 7, 2009 Posted October 7, 2009 Hi, I carry out annual inspections and put each new set of survey notes on a layer called by the date the survey was carried out. I have just found out that last year I didn't put my survey notes on the correct layer. Is there a way of determining when a line / text was created or placed in the drawing, like a date created? Any suggestion are welcome Thanks John Quote
stevsmith Posted October 7, 2009 Posted October 7, 2009 Only a drawing has creation dates and not individual items e.g lines, blocks etc. Quote
ReMark Posted October 7, 2009 Posted October 7, 2009 Not that I am aware of. However, you might be able to zero in on the date by seeing if AutoCAD created a LOGFILE (.log) in the folder listed under Tools > Options > Files tab. Expand the entry for Log File Location. Normally one would have to check off the option Maintain a log file on the Open and Save tab for this to happen. Also check out the commands LOGFILEON, LOGFILEOFF and LOGFILEMODE in your Help files. Don't be discouraged if you do not see a .log file in the folder. It is not uncommon for Explorer to overlook files of this type. Use Explorer to specifically look for *.log files. When the list is complete you can identify the log files for drawings as they include the drawing name as part of the log file name. Thus, if you have a drawing named 56RE201 the log file name may appear as 56RE201_1_1_5433.log. Good luck. Hope you find what you are looking for. Quote
fuccaro Posted October 7, 2009 Posted October 7, 2009 Lines, texts and other entities are recorded by AutoCAD as they are created. How about some Lisp? The sequence (SETQ e (ENTNEXT)) will assign the name "e" to the first entity in the drawing. Now if you run repetatedly (ENTGET (SETQ e (ENTNEXT e))) you will get the next entity data for each run. I admit that the returned data is somehow criptyc for the nonlispers but maybe you will be able to determine the first and the last desired data, all the next created inbetween those will be returned one after the other. Quote
