I made a function that asks user for new horizont and it then turns UCS accordingly. So selected line is taken as reference for new horizontal axe (X).
Problem is I calculate angle using ANGLE function. It returns radians. But
(command "ucs" "z" (* -1 Ang) ) accepts only Degree values for Ang. So I have to convert radians to degrees. I use following function:
(defun Rad2Deg (a)
(/ (* a 180.0) pi))
BUT! Is this conversion 100% correct? I suspect, that value in degrees is beeing slightly rounded. For like 1^-10...
Can I be sure, that this is not the issue? Is this Rad2Deg pure 100% correct?
You will never get a PC to be 100% accurate when dealing with real numbers. ACAD uses 15 significant digits. Always try to use ( equal n n fuzz ) when comparing reals. It will save you a lot of headaches. -David
chavlji,
Your function is as good as it gets. As David said, Autocad is limited to 15 decimal places. As a practical matter, that's pretty damned accurate. Using your function and its inverse, I experimentally converted a variety of numbers from radians to degrees and back 32 times for each case and there was no loss of accuracy.
Just a nit pick. 'puters use 16 significant digits or places, ( less 1 for negatives ). It will drop the decimals beyond that. It makes a difference with really large numbers.
Command: (setq r1 1234567890123.45678901234)
1.23457e+012
Command: (rtos r1 2 14)
"1234567890123.456"
-David
1.23457e+012
"1234567890123.456"
-David
Thanks for the less on David. :)
Did you know that Autocad has a way to do this...
UCS > OBject (or Entity)
