Hello,
I wrote a VBA program that exports several drawings from paperspace to model, using following code for each drawing:
1. SendCommand "_exportlayout "
2. SendKeys "d:\example.dwg" 'specify destination file
3. SendKeys "{ENTER}" 'export
4. Application.Wait (Now + TimeValue("0:00:10")) 'wait for export to finish
5. SendKeys "{ENTER}" 'open exported drawing
As I didn't know how tu use exportlayout command with parameters specyfying destination file and whether I wish to open exported drawing or not, I had to use SendKeys function.
Sometimes export takes so long, that application "forgets" keys that i send in line 5, so i had to add line 4.
But now the program needlessly waits for smaller drawings, that export quite fast, and sometimes breaks for exceptionally large drawings, when 10s delay is not enough.
So, my question is:
Is it possible to specify destination file and whether to open exported drawing, using command parameters so I wouldn't have to use SendKeys function?
Or maybe somehow tell the program to wait while AutoCAD is busy converting the drawing?
Thanks in advance for any reply.
PS. My program was written in Excel VBA.
PPS. If it's impossible to do it in VBA, maybe it possible to solve this problem with LISP routine?
