I made a Circular glass, then after rendering it became polygonal shape. Btw i used AutoCAD ver 2007 in rendering. I hope can figure my problem about rendering. So how is this? What properties should I change? give me some guides.. Before anything else, zoom the image
so that you can see the changes of the glass.
Thanks....
Sorry for my bad english.. I hope you understand what i mean.
I have changed the title of your thread - please use more descriptive titles in the future
type "facetres" in the command, if the value is 0.5 change it to 10 which is the highest, this should fix your problem..check viewres,surftab1, surftab2 as well, increase their size as necessary, check out help for further info.
