Support file search path
As above: Is it got any limit number of path?
Looks like one of path keep disappearing any time I start new sesion.
Try moving that path to the top of the list and see if it stays.
there was a problem years ago where any path not found on start up would be binned. This was cured with the introduction of the "Working support file search path" but I can't remember when that was.
Is your profile being loaded correctly? AutoCAD could be loading an out of date profile.
OK looks like it has limit of 18 lines only.(Autocad 2002)
Any time try to put new path it stay in open session but disappear when start new one and it is last one ion bottom of list. Looks like need to move my all lisp file into one folder, rename some. OK something to work on for Thanksgiving holiday.
Thanks anyway.
Everything work perfectly normal I assume it is loaded correctly.
Thanks anyway.
or upgrade to a newer version - my copy of 2008 has just retained 26 folders :)
I love my 2002...
Already upgrade (read purchase new set-too late for upgrade) to 2008
but still work on 2002.
Export my customization to 2008 and looks like 2002 still work on it (customization)
