hiddenline Posted July 11, 2008 Posted July 11, 2008 Hey everyone! I just installed Autodesk 2009- wow! I've been working on 2005 for the last couple years, so I've got some work to do to get everything set up. I'm trying to load express tools. I typed express tools, nothing happens. I type appload and got to C:\programfiles\Autocad2009\Express There's alot of lsp files in there! I use Copy/Rotate (cr) and Move/Rotate (mr) allll day. But, i don't see the lsp routine in this list. When i type expressmenu nothing happens either. I right-click on the toolbar and there isn't a choice to select Express So I type menuload- no express tools there So I browse to Autocad folder and click on Express. it says the file is empty. I change the file-type pulldown to mns, cui, mnu type files...it still says it's empty. Am I looking in the wrong locaiton for the menu to load? Help! Thanks everyone! Quote
ReMark Posted July 11, 2008 Posted July 11, 2008 There is no Express Tools content in the Ribbon. But you can make it happen. Start with this link: http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6176 Quote
hiddenline Posted July 11, 2008 Author Posted July 11, 2008 Thanks Remark! I got the menu loaded!! However, I don't see Move/Rotate or Copy/Rotate anymore! Only MOCORO. Yuck. that's too long. Do you know if they got rid of mr and cr? when I type it in, it doesn't recognize it. Thanks again! Quote
Cad64 Posted July 13, 2008 Posted July 13, 2008 Move/Rotate and Copy/Rotate? Are you sure those aren't custom lisp routines? MR and CR commands don't exist in Autocad. Quote
Milissa Posted March 18, 2010 Posted March 18, 2010 Remark, I too am trying to add express content to my ribbon in 09 Civil 3D. I used the directions from the cadforum's link you provided. After I check the box and closed nothing happens. If I go back to the CUI file the box is unchecked. Any advice? Thanks! Quote
ReMark Posted March 18, 2010 Posted March 18, 2010 Maybe you did not switch to the current workspace as required. Quote
Milissa Posted March 19, 2010 Posted March 19, 2010 Thanks for the response ReMark. I went through the process again and again. Unfortunately, I did switch to the current workspace. I even tried creating new workspace and setting it current, but it still didn't work. I do find it strange that after I have set my workspace current and have selected to customize it and have checked the ribbon panel box under partial CUI files that the workspace contents on the right does not show a change in contents. Thanks for your help. Quote
