I am looking for a way to browse for multiple drawings and populate a list box with all the file paths in VBA
Thanks in advance
-KarL-
What do you have so far? Thats actually a little bit difficult, as VBA doesn't have the filedialog box built in. It is very doable though
Right now I use a function that references the Excel file open dialog. It works most of the time but lately it is causing problems since we are upgrading some compters to office 2007 so I would like to get rid of the excel reference if possible.
   Set ExcelApp = GetObject(, "Excel.Application")
   If Err <> 0 Then
       Err.Clear
       Set ExcelApp = CreateObject("Excel.Application")
       If Err <> o Then
           MsgBox "Could not start Excel!", vbExclamation
           End
       End If
   End If
   ExcelApp.Visible = True
   Set wbkobj = ExcelApp.Workbooks.Add
   Set shtObj = wbkobj.Worksheets(1)
   BrowseDialogMulti = excel.Application.GetOpenFilename(FileFilter:=(FileType & " (*" & Extension & "),*" & Extension & ", All Files (*.*),*.*"), Title:=Title, MultiSelect:=True)
   ExcelApp.Quit
I haven't played with office 07 yet, so Im not sure how its going to work. Obviously, they (Microsoft) have changed the way you access that box
I often connect to this windows browse box because it is small and easy to prompt the user for one file like a block.
Dim objDialog As Variant, intResult As Variant,
Dim strFilePath As String
Set objDialog = CreateObject("UserAccounts.CommonDialog")
'Use The Common Dialog, show open method to get the profile
objDialog.Filter = "Select block (*.DWG)|*.dwg"
objDialog.FilterIndex = 1
objDialog.InitialDir = "C:\"
intResult = objDialog.ShowOpen
If intResult = 0 Then
 Exit Sub
Else
'Get the full path and filename
 strFilePath = objDialog.FileName
End If
Msgbox  strFilePath
End Sub
However, it does not support multi file selctions that I am aware of.
There is Common Open File Dialog box code out there that a lot of other CAD guys use; because of the large amount of code it uses, I only use it in the case that I need advanced features like multi select etc.
Here is an example of that code
Good luck
ML
Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias _
"GetOpenFileNameA" (pOpenFileName As OPENFILENAME) As Long
Private Type OPENFILENAME
lStructSize As Long
hwndOwner As Long
hInstance As Long
lpstrFilter As String
lpstrCustomFilter As String
nMaxCustFilter As Long
nFilterIndex As Long
lpstrFile As String
nMaxFile As Long
lpstrFileTitle As String
nMaxFileTitle As Long
lpstrInitialDir As String
lpstrTitle As String
flags As Long
nFileOffset As Integer
nFileExtension As Integer
lpstrDefExt As String
lCustData As Long
lpfnHook As Long
lpTemplateName As String
End Type
Sub Test()
Dim Filter As String
Dim InitialDir As String
Dim DialogTitle As String
Dim OutputStr As String
Filter = "Drawing Files (*.dwg)" + Chr$(0) + "*.dwg" + Chr$(0) + _
"All Files (*.*)" + Chr$(0) + "*.*" + Chr$(0)
InitialDir = "C:\Documents and Settings\%username%\Desktop"
DialogTitle = "Open a DWG file"
OutputStr = ShowOpen(Filter, InitialDir, DialogTitle)
MsgBox OutputStr
End Sub
Public Function ShowOpen(Filter As String, _
InitialDir As String, DialogTitle As String) As String
Dim OFName As OPENFILENAME
'Set the structure size
OFName.lStructSize = Len(OFName)
'Set the owner window
OFName.hwndOwner = 0
'Set the filter
OFName.lpstrFilter = Filter
'Set the maximum number of chars
OFName.nMaxFile = 255
'Create a buffer
OFName.lpstrFile = Space(254)
'Create a buffer
OFName.lpstrFileTitle = Space$(254)
OFName.nMaxFileTitle = 255
'Set the initial directory
OFName.lpstrInitialDir = InitialDir
'Set the dialog title
OFName.lpstrTitle = DialogTitle
'no extra flags
OFName.flags = 0
'Show the 'Open File' dialog
If GetOpenFileName(OFName) Then
ShowOpen = Trim(OFName.lpstrFile)
Else
ShowOpen = ""
End If
End Function
Cmd
In Office 2007, it is now called The Ribbon.
While it take some time to get use to, there are a lot of new and advanced features that I really like.
If you are a big Excel junky like me, then this will be a real help.
It is very good for referencing 2003 to see what you need in 2007
http://office.microsoft.com/assistance/asstvid.aspx?assetid=XT101493291033&vwidth=1044&vheight=788&type=flash&CTT=11&Origin=HA101491511033
ML
I got the code to work but it is still only allowing me to select one drawing. What do I need to change to get multiple drawings?
I dont have my souce with me (Im at work), but essentially you have to change the FLAGS variable in the OPENFILENAME UDT. Its a bit of AND'ing of the bits and, like a lot of things API, not many people memorize it, only plagarize it.
Also, once you start returning multiple filenames, you have to parse out the indiviual filenames from what comes back as a multiple-null string, and pack that back into a variant. The first part of the returned string will be the PATH only, then an ascii zero, then followed by each individual filename ONLY, without the path, each followed by another ascii zero. The SPLIT function works well here; but you have to remember to add the PATH back in front of each filename.
Confusing? Possibly. While it can be fun to learn, a copy-and-paste module is oh-so-convenient....
well, I found some source online and patched it quick, I apologize to whomever I plagarized from; but anyhoo, here it is.
The code will open many types of files, and many files at once; you may see that the file open allows selecting both .DWG and .DXF in the same dialog window.
Yes, i see a discrepancy with the code returning filenames with a double backslash "\\" if multiple files are opened from the root drive;
but Im on lunch, dont have time to fix it, and it works anyway, even with the double backslashes. So sue me ...
' --------- snip ----- snip -------------
Public Type OPENFILENAME
lStructSize As Long
hwndOwner As Long
hInstance As Long
lpstrFile As String
nMaxFile As Long
flags As Long
lCustData As Long
lpfnHook As Long
End Type
Public Declare Function GetOpenFileName Lib "comdlg32.dll" Alias _
Public Const OFN_ALLOWMULTISELECT = &H200&
Public Const OFN_EXPLORER = &H80000
Public Const OFN_FILEMUSTEXIST = &H1000&
Public Const OFN_HIDEREADONLY = &H4&
Public Const OFN_PATHMUSTEXIST = &H800&
Sub SelectManyFiles()
Dim FileList As New Collection
Dim I As Long
Dim S As String
ShowFileOpenDialog FileList
With FileList
If .Count > 0 Then
S = "The following files were selected:" + vbCrLf
For I = 1 To .Count
S = S + .Item(I) + vbCrLf
Next
MsgBox S
Else
MsgBox "No files were selected!"
End If
End With
End Sub
Sub ShowFileOpenDialog(ByRef FileList As Collection)
Dim OpenFile As OPENFILENAME
Dim lReturn As Long
Dim FileDir As String
Dim FilePos As Long
Dim PrevFilePos As Long
With OpenFile
.lStructSize = Len(OpenFile)
.hwndOwner = 0
.hInstance = 0
.lpstrFilter = "AutoCad Drawings" + Chr(0) + "*.dwg;*.dxf;" + _
Chr(0) + "All Files (*.*)" + Chr(0) + "*.*" + Chr(0) + Chr(0)
.nFilterIndex = 1
.lpstrFile = String(4096, 0)
.nMaxFile = Len(.lpstrFile) - 1
.lpstrFileTitle = .lpstrFile
.nMaxFileTitle = .nMaxFile
.lpstrInitialDir = "C:\"
.lpstrTitle = "Multi Select Drawings"
.flags = OFN_HIDEREADONLY + _
OFN_PATHMUSTEXIST + _
OFN_FILEMUSTEXIST + _
OFN_ALLOWMULTISELECT + _
OFN_EXPLORER
lReturn = GetOpenFileName(OpenFile)
If lReturn 0 Then
FilePos = InStr(1, .lpstrFile, Chr(0))
If Mid(.lpstrFile, FilePos + 1, 1) = Chr(0) Then
FileList.Add .lpstrFile
Else
FileDir = Mid(.lpstrFile, 1, FilePos - 1)
Do While True
PrevFilePos = FilePos
FilePos = InStr(PrevFilePos + 1, .lpstrFile, Chr(0))
If FilePos - PrevFilePos > 1 Then
FileList.Add FileDir + "\" + _
Mid(.lpstrFile, PrevFilePos + 1, _
FilePos - PrevFilePos - 1)
Else
Exit Do
End If
Loop
End If
End If
End With
End Sub
Sweet, thats what I needed!
Thanks everyone for the help.
-KarL-
Hi Karl
Unfortunately I can not give you that answer because I do not know.
I was given that code but never really needed t use it; I use the first one that I posted all of the time because I really ever only need to select one file at a time.
Try playing around with code and see what you get.
The other alternative is to just simply do a Google Search on ACAD and Open File Dialog; I assure you that you will get tons of hits.
If I get some time, may be I can look at it but the after is likely a click away.
Hmm, if you notice, there is a constant set for mutliselect, you will just need to know where to put it.
ML
  • 2 years later...
How do you get the above code to work in the last post.
When I cut/paste it in a form the following lines are in red.
Is there something I am missing?
Thank you,
Does it have to be in vba? I did something like this for a fas compiler. This is before I figured out a better way to secure my lisps.
edit____
I removed my fas compiler lisp so you can run with this if you choose to go this route
m-file.LSP
Program name.dcl
Edited by Lt Dan's legs
Thank you,
Wow. I posted that code many moons ago. The lines are coming back as RED, because "Public CONST" declares are not allowed in a Form Module. The Code posted there was to be dropped entirely into its own ".BAS" module, and then called FROM your Form Module.
You put related code into its own module, and then 'drag and drop' it into your
application whenever you need that functionality. That makes the code MODULAR.
Below is a newer version of that code. It has not only "File Open" dialog capabilities, but also "File Save" and "Browse for Folder" dialogs, as well. It also allows you to set your initial opening folder to a network drive - something VB alone doesnt let you do. The File Open routine accepts selection of One, or many, files. It returns a variant - EMPTY if no files selected, or an array of fully qualified pathspecs to each file selected.
Also, the first subroutine there, "Main", is basically a demo sub showing off the features. It is sample code. Try running it. You should be able to copy and paste code from that subroutine, into your FORM code, and it will run.
One Caveat - normally, "Open", Save", etc dialogs are MODAL from the App that calls them. They pop up, and you cant do anything until you are finished with the File Open Dialog. This code DOES NOT do that - if you click on another form, the File Open dialog will be drawn behind the other window. In order to make the dialogs MODAL, you have to get the memory address of your calling Application. I could hardwire in the Acad Window, but then this code wouldnt work in, say, Excel, or VB, or SolidWorks. So I cheated, and got the address of the Windows Desktop instead - but now the code should work anywhere.
CommonDialog.txt
Edited by rocheey
change word "Module" to "Subroutine" for sample code
  • 3 years later...
Hi,
Firstly, thank rocheey to show his code. However it still has some errors. I have tried to fix it and it works perfectly for me.
Here is the code, hope it help you so much.
lStructSize As Long
hwndOwner As Long
hInstance As Long
lpstrFile As String
nMaxFile As Long
flags As Long
lCustData As Long
lpfnHook As Long
End Type
Private Const OFN_ALLOWMULTISELECT = &H200&
Private Const OFN_EXPLORER = &H80000
Private Const OFN_FILEMUSTEXIST = &H1000&
Private Const OFN_HIDEREADONLY = &H4&
Private Const OFN_PATHMUSTEXIST = &H800&
Dim I As Long
Dim S As String
With FileList
If .Count > 0 Then
For I = 1 To .Count
Next
MsgBox S
Else
End If
End With
End Sub
Dim lReturn As Long
Dim FilePos As Long
With OpenFile
.hwndOwner = 0
.hInstance = 0
.nFilterIndex = 1
OFN_EXPLORER
If lReturn <> 0 Then
Else
Do While True
Else
Exit Do
End If
Loop
End If
End If
End With
End Sub
  • 11 months later...
Hi tuntnguyen,
I copied your code, and it works perfectly
However,...
I need to open the drawings one by one (a LISP routine will edit each drawing, using acaddoc)
In which variable can I find the drawings, and how do I open them accordingly?
Before I used a fixed directory to place the drawings which had to be edited
VBA created a list of all the drawings in this directory in the variable "Drawing"
Below you find my "opening" code:
Do While Len(Drawing) > 0
          Tekopen = Input_Dir & "\" & Drawing
          AutoCAD.Documents.Open (Tekopen)
          AutoCAD.ActiveDocument.Close
          Drawing = Dir()
Loop
Anyone can support me in this one?
Regards,
Frans
  • 4 weeks later...
Hi all,
Can someone help me with the above problem?
Thanks,
Frans
