i have create a program that run smoothly on my computer. but when i run the program using other computer. it will give error "cannot find project or library" and highlighted at str(variable) and left(variable).can someone explain to me what possibilities that lead to this problem...thanks..
Check your References.
Alt-F11 to wake up the VBA editor then Tools>References on both machines to see which references are loaded (checked).
Check the references on the malfunctioning machine are the same as your own machine and try again.
