When using angular dimension it shows an "1/8" instead of a the degree symbol. If a edit the dimension text it shows "".
Any help in getting the degree symbol to appear would be appreciated.
Sounds like the font that you are using in you dimstyle doesn't support the degree symbol. Try making a piece of text using the textstyle you are using in your dimstyle with the characters %%D and see what happens.
Just a wild guess in an idle moment, have you got the angular dimensions set to grads, and the lower case "g" might look like an "8" :?
It was the text style! Changed the font and all is well.
THANKS!
