Just wondering if anyone out there has some code that can select a specific line within a group of lines and then change that color of that line??
Can you clarify a little. How are the lines grouped? Why cant you just use the conventional method of selecting the line and changing its properties?
If iv missed something within the question my apologies.
well to specify, im using a selection set....here is a sample of my beggining code:
Function ChangeColorOfLayouteight(strErrors)
Dim S99 As AcadSelectionSet
Dim Ftyp(5) As Integer
Dim errCount As Long
'Dim strErrors As String
Dim Fval(5) As Variant
Dim dEnd As Variant
'* Program Begins
'* Looks for outer contour of LO1 Doc. to Red
Ftyp(0) = -4: Fval(0) = "<AND"
'Ftyp(1) = -4: Fval(1) = "<OR"
Ftyp(1) = 0: Fval(1) = "LINE"
Ftyp(2) = 67: Fval(2) = "0"
Ftyp(3) = 5: Fval(3) = "BD8"
'Ftyp(5) = 5: Fval(5) = "BD8"
'Ftyp(6) = 5: Fval(6) = "C37"
'Ftyp(7) = 5: Fval(7) = "C36"
'Ftyp( 8 ) = 5: Fval( 8 ) = "C1F"
'Ftyp(9) = 5: Fval(9) = "C35"
'Ftyp(10) = 5: Fval(10) = "C34"
'Ftyp(11) = 5: Fval(11) = "C33"
'Ftyp(12) = 5: Fval(12) = "C32"
'Ftyp(13) = 5: Fval(13) = "C31"
'Ftyp(14) = 5: Fval(14) = "C30"
'Ftyp(15) = 5: Fval(15) = "C2F"
'Ftyp(16) = 5: Fval(16) = "C2E"
'Ftyp(17) = 5: Fval(17) = "C2D"
'Ftyp(1 8 ) = 5: Fval(1 8 ) = "C2C"
'Ftyp(19) = 5: Fval(19) = "C2B"
'Ftyp(4) = -4: Fval(4) = "OR>"
Ftyp(4) = -4: Fval(4) = "AND>"
'ThisDrawing.SelectionSets("S99").Delete
Set S99 = ThisDrawing.SelectionSets.Add("S99")
S99.Select acSelectionSetAll, , , Ftyp, Fval
If S99.Count > 0 Then
For errCount = 0 To S99.Count - 1
S99(errCount).color = acWhite
'S99(errCount) = "0.03"
Next errCount
End If
End Function
Correct me if im wrong but 'q select' is for changing multiple objects/lines with common properties. My understanding of the original question was that one line is to be changed.
Cad O Cad,
Im bowing out not so gracefully, I take it your involved in some sort of cad programming or whatever, I was looking at it from a draughting point of view. Good luck anyway!!
Jay Dee,
yea i am lol..well your interest is greatly appreciated thank u !
Your code would have to cycle through the lines giving you the option to change its color/or not as I cannot think of a way to isolate one line from many unless it happens to be at a particular height "Z" in the drawing. Would that be the case?
Well what is happening is that i have a drawing that only certain lines need to be white and everything else needs to change when the rest of the program finish's.
