issue setting layers using tools in pallets
I'm using a custom tool in a pallet to insert a block. I have it set to repeat the command and here is where the issue is coming to play.
under the properties of the command you can assign what layer, linetype, etc. Basically the properties of what the block will be when inserted.
what is happening is on the repeat (using *^C^C) for the marco it inserts the first block perfectly, on the second on it still shows the layer on the insert layer however the block is placed on the current layer instead.
anyone run across this and know what is causing it? and more importantly how to fix it.
thanks.
