mojo8997 Posted October 13, 2009 Posted October 13, 2009 Im trying to figure out how to add on to an default autocad command. For example revcloud, i made a lsp to use the revcloud command the select an object, then change layer and pline width but i want it o run just like the regular autocad command. (i am trying to minimize errors on drawings i create and this would help out a lot.) I want to to that to many commands but the lisp just cancels out if i do it like this (defun c:REV() (command "_revcloud") (command "pedit" "L" "W" ".02" "") (command "chprop" "L" "" "LA" "REV" "") (princ) ) Quote
alanjt Posted October 13, 2009 Posted October 13, 2009 Try this: (defun c:Rev (/) (command "_.revcloud") (while (not (zerop (getvar "cmdactive"))) (command pause) ) ;_ while (command "_.pedit" (entlast) "_w" 0.02 "") (command "_.chprop" (entlast) "" "_la" "REV" "") (princ) ) ;_ defun Quote
mojo8997 Posted October 13, 2009 Author Posted October 13, 2009 Never mind it works if i hit O, thanks again Quote
