Hello All!
I am using DWGPROPS to populate my titleblock using custom commands and fields. It has saved a lot of time, but there are a couple of things that would help make it better, and either I am not searching for the right thing, or its not possible (which I dont believe...autocad can do anything!).
Firstly, I want to be able to invoke dwgprops automatically when a new template is opened.
Second, before using dwgprops and fields, the titleblock was set up using attributes, so navigating to different values was easy because you could just hit the ENTER key. However, in dwgprops, I don't know how to tab down to the next value without clicking with the mouse. It would be a lot easier accomplish all info just using the keyboard...
Any ideas?
Hello All!
Any ideas?
TAB will jump the the next available field.
I tried that, and it just tabs over to the Add button, and then to the OK button.
