rkmcswain Posted July 14, 2008 Posted July 14, 2008 Here is a tip on how to disable InfoCenter in AutoCAD 2008. It also works for 2009, just use replace 17.1 with 17.2 in the registry string. http://otb.manusoft.com/2007/09/autocad-2008-slow-startup-fix.htm Quote
alanjt Posted July 14, 2008 Posted July 14, 2008 just to make things extra easy, here it is in vlisp: (vl-registry-write (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\InfoCenterAcConn" ) "LOADCTRLS" 0 ) Quote
tzframpton Posted July 15, 2008 Posted July 15, 2008 Thank God for this tip. That damn thing gets annoying... Quote
BOB'27T Posted July 16, 2008 Posted July 16, 2008 Not to appear to be a moron, but where do you go to disable this function. I went to the info center, but didn't seem to find what I needed. Please try not to laugh at my ignorance! Quote
alanjt Posted July 16, 2008 Posted July 16, 2008 Not to appear to be a moron' date=' but where do you go to disable this function. I went to the info center, but didn't seem to find what I needed. Please try not to laugh at my ignorance![/quote']if you'll just paste the code i posted above in the commandline, it will turn it off for you. Quote
BOB'27T Posted July 18, 2008 Posted July 18, 2008 I finally had a chance to try pasting in the code, but it came up with an error message. All I did was copy & paste into the commandline. What am I doing wrong? Quote
alanjt Posted July 18, 2008 Posted July 18, 2008 I finally had a chance to try pasting in the code' date=' but it came up with an error message. All I did was copy & paste into the commandline. What am I doing wrong?[/quote']probably missing a paren on paste. draw attachment into autocad and it will run. hope this helps. no comm center.lsp Quote
kheylan Posted May 17, 2009 Posted May 17, 2009 Type (vl-load-com) in command line and try one more time. If it work write this expression to acaddoc.lsp file Acaddoc.lsp Quote
Lee Mac Posted May 19, 2009 Posted May 19, 2009 just to make things extra easy, here it is in vlisp: (vl-registry-write (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\InfoCenterAcConn" ) "LOADCTRLS" 0 ) Nice Alan Quote
CadDog Posted September 29, 2009 Posted September 29, 2009 I was looking for a way to stop the second command line from always popping up and by adding this little code it stopped... Thanks all... BTW: I googled to find this answer and found this thread. I love google... Quote
mtaussie Posted April 19, 2010 Posted April 19, 2010 For some reason this does not work on my machine. I tried that code in hopes that i can get some other code to work. I am actually trying to change a setting for the Cad manager Channel (vl-registry-write (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\CadManagerControl\\Infocenter") "EnableCadMgrChannel" 1) I was about give up after reading in the help file that its not possible. In the help file it states "Note: You cannot use vl-registry-write for HKEY_USERS or KEY_LOCAL_MACHINE." I am running Win7 64bit, could this be an issue? Quote
