Nilesh Jagtap Posted October 15, 2009 Posted October 15, 2009 Printer- Designjet 500 plus 24 (32 mb ram) Dwg- 1.8 mb autocad 2008, XP Professional i have one dwg of size 1.8 mb but it is not getting printed plotter showing the error "Out of memmory data was lost" Error 71:06 I have tried with other same type of dwgs of size more than this one and get printed with no errors. I have purged both of these dwg before print. above dwg contains one Topo-Survey map (block) I think there is problem with that dwg only. Anybody plz help me to solve this problem asap. any reply will be appriciated. Quote
Organic Posted October 15, 2009 Posted October 15, 2009 The problem is not the drawing, it is you're printer. I.e. if you're printer has 64Mb built in memory and the print job you are sending is 80Mb (they are always far larger the print jobs and their spooling than the file itself) then it simply won't be able to spool it and print it. Quote
NBC Posted October 15, 2009 Posted October 15, 2009 There should be the facility within the Properties of the Printer (access through Printers and Faxes on Windows Control Panel). Right click on the Printer, select Properties, navigate to the Advanced tab. There should be an option to choose to "spool print documents" or "start printing immediately" Try printing your drawing by changing this setting Quote
ReMark Posted October 15, 2009 Posted October 15, 2009 Is it just this one drawing you are having a problem printing? Have you run an AUDIT on the drawing? Quote
Nilesh Jagtap Posted October 15, 2009 Author Posted October 15, 2009 Is it just this one drawing you are having a problem printing? Have you run an AUDIT on the drawing? yes...i have done all settings on printer like "send job as a bitmap image" (process in computer) plz check attachement here with autocad audit log file. Quote
Nilesh Jagtap Posted October 15, 2009 Author Posted October 15, 2009 but while spooling this file it is showing 560 kb Quote
ReMark Posted October 15, 2009 Posted October 15, 2009 Have you purged unused regapps? Have you pared down the scalelists? Quote
Nilesh Jagtap Posted October 15, 2009 Author Posted October 15, 2009 yes...i have done all settings on printer like "send job as a bitmap image" (process in computer) plz check attachement here with autocad audit log file. one more thing i am taking print of other dwg having x-ref (images) of 15 mb and spooling showing 110 mb still there is no error instead this file showing 560 kb while spooling and then on plotter showing error.... i can't understand ...bcoz i have drawn same dwg again but still thr is problem. Quote
Nilesh Jagtap Posted October 15, 2009 Author Posted October 15, 2009 Have you purged unused regapps? Have you pared down the scalelists? no how to do this..? but i have done "purged all" Quote
Nilesh Jagtap Posted October 16, 2009 Author Posted October 16, 2009 Is it just this one drawing you are having a problem printing? Have you run an AUDIT on the drawing? audit log file audit log.txt Quote
Organic Posted October 16, 2009 Posted October 16, 2009 I don't think the Audit has anything to do with it. Quote
ReMark Posted October 16, 2009 Posted October 16, 2009 I don't think the Audit has anything to do with it. Neither do I but it would rule out internal errors in the drawing file as a possible culprit would it not? Quote
