richard3009 Posted October 15, 2009 Posted October 15, 2009 Autocad LT 2008 I wish to insert drawing numbers into a batch of around 500 autocad files without opening them and doing it manually, is there a solution. Thank you Quote
ReMark Posted October 15, 2009 Posted October 15, 2009 Given that you are using LT I think a script would be in order. Quote
richard3009 Posted October 15, 2009 Author Posted October 15, 2009 It doesn't have to replace an existing number, as long as I can place incrementing numbers somewhere in the borders of each file, either by targeting an attribute, or a co-ordinate, although the latter may be a little tricky if the drawings are in different global positions Quote
ReMark Posted October 15, 2009 Posted October 15, 2009 Take a look at ScriptPro at the AutoDesk website. Quote
