PEcomStock Posted October 16, 2009 Posted October 16, 2009 I gave my students (using 2010) an assignment that involved creating walls for a building. The overall outside dimensions were 24' x 18' x 4". In completing the drawing, some students used the OFFSET command to create the 4" thick walls, others used multilines. When the students displayed the drawing in paper space, the students using the OFFSET command had the correct dimensions. However, the students using multilines could not get the program to dimension correctly. For example, a multiline showed a true dimension of 120" displayed as 4.14" which is the scaled down length in paper space. By contrast, the equivalent dimension for a single 120" line just below the multiline displayed as 120". Out of curiosity, I ran a 2006 version of AutoCAD and the same problem occurred. Is this a known bug? Quote
ReMark Posted October 16, 2009 Posted October 16, 2009 Not that I am aware of. I'll have to test that out. Well I'll be darned. You're right. Guess I don't use Multiline that often. By the way, I tested it using AutoCAD 2009. Quote
PEcomStock Posted October 16, 2009 Author Posted October 16, 2009 Does AutoCAD monitor this forum or do I need to report it directly to AutoCAD. If so, can you suggest the most effective contact? Quote
ReMark Posted October 17, 2009 Posted October 17, 2009 I can't tell you if AutoDesk monitors this forum. You could try posting over at the AutoCAD Users Group International (AUGI) forum or at the AutoDesk Discussion Groups. Start with these links. In both cases you'll have to register but membership is free. www.augi.com http://discussion.autodesk.com/forums/ Quote
ReMark Posted October 17, 2009 Posted October 17, 2009 You can also post questions at the AutoCAD Exchange: http://autocad.autodesk.com/ Quote
