when using any command not just qsave i get the error below, thats directly from the command line. All the commands funtion properly so its not a big deal just wanted to know why it does that? what is vppromt? it says unknown command if i type it in the command line.
Command: qsave
; error: no function definition: VPPROMPT
._QSAVE ; error: no function definition: VPPROMPT
And when did this problem first occur?
Have you loaded any new lisp routines lately have you?
I think your computer is possessed.
It happened for a while then stopped when i got a new hard drive and now is happening again. Maybe the ghost of my old hard drive is back?
I forgot i posted that. I took that lisp out of my startup suite and closed autocad and reopened it and got
Loading Acad Title Block ARX application ....OK!
DMSTB ; error: no function definition: VPPROMPT
Command:
Command:
Command: (COMMAND "NETLOAD"
"G:\\PROGRA~1\\Bentley\\PROJEC~1\\bin\\AutoCAD\\IDODMA~1.DLL")
NETLOAD ; error: no function definition: VPPROMPT
Assembly file name: G:\PROGRA~1\Bentley\PROJEC~1\bin\AutoCAD\IDODMA~1.DLL
Command: nil
Command: _RIBBON
Command: COMMANDLINE
