mikyrom Posted October 17, 2009 Posted October 17, 2009 Saving a drawing it creates a backup file with BAK extension. Can somebody tell me how to open the BAK file? Quote
mikyrom Posted October 17, 2009 Author Posted October 17, 2009 It doesn't work changing the extension. Somebody know another way? Quote
Cad64 Posted October 17, 2009 Posted October 17, 2009 Of course it does. If you're file is named Drawing.bak, rename it to Drawing.dwg and you will be able to open it, unless the file is corrupted. Quote
alanjt Posted October 17, 2009 Posted October 17, 2009 It doesn't work changing the extension.Somebody know another way? That is the way. Something must be wrong with your .bak file. Quote
mikyrom Posted October 17, 2009 Author Posted October 17, 2009 It gives me the following error: "the file is not a valid Win32 application" What I'm doing wrong? Quote
alanjt Posted October 17, 2009 Posted October 17, 2009 It gives me the following error: "the file is not a valid Win32 application" What I'm doing wrong? Can you post the file? Quote
mikyrom Posted October 17, 2009 Author Posted October 17, 2009 It's okey. It was from the settings from Windows, I added just .dwg but the file didn't change. It was a stupid question from. Thank you Quote
alanjt Posted October 17, 2009 Posted October 17, 2009 It's okey.It was from the settings from Windows, I added just .dwg but the file didn't change. It was a stupid question from. Thank you No stupid questions, only stupid people. Glad you figured it out. Quote
nocturne00 Posted October 17, 2009 Posted October 17, 2009 Additionally for others who run into this type of situation reading this, before changing an extension, under any open Windows explorer window>TOOLS>FOLDER OPTIONS>VIEW tab> uncheck "Hide extentions for known file types". it goes for recovering from the .$vs file as well.. Quote
