LauKwokFai Posted October 18, 2009 Posted October 18, 2009 I have this CAD file showing a general layout plan, when I checking the drawing, I found there were lots of "invisible" objects in my drawing. (for example it tells me there are 165 objects in "g-str" layer, but I only see 3 objects on screen). At last I found that those "invisible" objects has an additional assoc code (60 . 1). It became "visible" when I change it back to (60 . 0). Check the objects again the (60. 0) has gone. can somone tells me what had happened to my drawing ? or it is a new feature of autocad and may be I accidentally put the objects into invisible. Thanks so much !! Quote
SEANT Posted October 18, 2009 Posted October 18, 2009 The ability to make entities visible/invisible (regardless of layer settings) has been with AutoCAD for some time, though never available through standard commands; only through programming (Lisp, VBA, ARX, .NET, etc.). I’ve seen a few Lisps routines around that perform that function, and I posted a VBA version here: http://www.cadtutor.net/forum/showpost.php?p=85361&postcount=5 The UnHideAll sub, or similar Lisp (if one can be found), should quickly reveal all invisible objects (again, layer settings notwithstanding). Quote
LauKwokFai Posted October 18, 2009 Author Posted October 18, 2009 hmmm...it is strange, I am the only one who knows Lisp in the office !!!! wonder how this happen !? Thank you anyway ! Quote
SEANT Posted October 18, 2009 Posted October 18, 2009 Actually, I should mention that some of the AutoCAD verticals (Architect, Mechanical, Electrical, etc.) may have the ability to modify an entity's visibility. Quote
LauKwokFai Posted October 18, 2009 Author Posted October 18, 2009 I really doubt it, we are a small interior design company, no one in this office knows Lisp, some of them don't even heard of Autolisp !! Is it can only be done on purpose ? Quote
lamensterms Posted February 8, 2012 Posted February 8, 2012 I have this CAD file showing a general layout plan, when I checking the drawing, I found there were lots of "invisible" objects in my drawing. (for example it tells me there are 165 objects in "g-str" layer, but I only see 3 objects on screen). At last I found that those "invisible" objects has an additional assoc code (60 . 1). It became "visible" when I change it back to (60 . 0). Check the objects again the (60. 0) has gone. can somone tells me what had happened to my drawing ? or it is a new feature of autocad and may be I accidentally put the objects into invisible. Thanks so much !! hi LauKwokFai, i know this is a very old thread - i was just wondering if you could please tell me how you checked and changed the value of DXF code 60? Cheers Quote
Patrick Hughes Posted February 9, 2012 Posted February 9, 2012 lamensterms, One way of doing it without even knowing lisp is to DXFOUT the drawing. Open the DXF file in Notepad then find and replace (60 . 0) with (60 . 1) or the other way around. Try it on a junk drawing first. Quote
LauKwokFai Posted April 19, 2013 Author Posted April 19, 2013 hi LauKwokFai, i know this is a very old thread - i was just wondering if you could please tell me how you checked and changed the value of DXF code 60? Cheers Hi lamensterms, Happened to look back at my old threads and see this old thread ! I tried to erase everything and purge a layer, it said there were objects in the layer. Then I used (ssget "x" (list (cons 8 "layerName"))) to select all objects, took (assoc 10) and (assoc 11) of every objects and draw a line, it turned out a whole structural plan. Then I (entget) a hidden object, compared it with normal object and found there is an extra (60 . 1). Didn't know what to do and tried to replace (60 . 1) by (60 . 0) and the objects became visiable. As I said it is very strange because this is our company internal drawing, nothing imported from other company and no one in our office knows anything about autolisp. I still cannot figure out how this happened. Quote
BIGAL Posted April 22, 2013 Posted April 22, 2013 Try this not tested (setq ss (ssget "X")) (setq len (sslength ss)) (repeat len (setq en1 (ssname ss (setq len (- len 1)))) (setq el1 (entget en1)) (setq el (subst (cons 60 0) (assoc 60 el1) el1)) (entmod el) ) Quote
neophoible Posted April 22, 2013 Posted April 22, 2013 Since this has been reactivated... Newer versions of AutoCAD have HideObjects, IsolateObjects, and UnIsolateObjects. Another variation using AutoLISP (be sure you run the very first line): (vl-load-com) (defun C:Cloak (/ selset index) (prompt "Select objects to cloak...") (setq selset (ssget) index (sslength selset)) (repeat index (vla-put-Visible (vlax-ename->vla-object (ssname selset (setq index (1- index)) ) ) :vlax-false ) ) (princ) ) (defun C:DeCloak (/ selset index) (setq selset (ssget "X" '((60 . 1))) index (sslength selset)) (repeat index (vla-put-Visible (vlax-ename->vla-object (ssname selset (setq index (1- index)) ) ) :vlax-true ) ) (princ) ) Quote
BIGAL Posted April 23, 2013 Posted April 23, 2013 Nice one neophoilbe thats why I am moving more to vl you can get to the properties a lot easier I wondered about visibility when I posted meant to do a couple of dumpit's. Line ; Visible = -1 Quote
neophoible Posted April 23, 2013 Posted April 23, 2013 Thanks, BIGAL. Actually, I'm just piggybacking off some of the work of some others. I just rearranged it, made it a bit more AutoCADish, and a bit harder to read;); and of course the naming is in honor of one of my old favorites. Quote
