Simple153 Posted October 19, 2009 Posted October 19, 2009 Menu fatal error: A name contained an invalid character. Menu file: C:\Documents and Settings\AlanM\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\support\acad.cui Opening an AutoCAD 2004/LT 2004 format file. Regenerating model. Press ENTER to continue: AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. AutoCAD menu utilities loaded. Autodesk DWG. This file is a Trusted DWG last saved by an Autodesk application or Autodesk licensed application. Quote
Simple153 Posted October 19, 2009 Author Posted October 19, 2009 Mark Thanks for your eply, but what so you mean? Quote
ReMark Posted October 19, 2009 Posted October 19, 2009 Did you, or someone else, happen to customize the acad.cui file? Did you add any macro buttons? Any new toolbars? Rearrange some toolbars? Or other? Quote
